Local time step
Like Tree3Likes
  • 2 Post By akidess
  • 1 Post By ramhari
Old   June 16, 2011, 02:23
Default Local time step
ramhari is on a distinguished road
I want to use local time steps to converge to steady state quickly. I have fixed the maxCo and want to calculate deltaT for each cell (local time step). My Openfoam rho (for e.g.) equation reads :
rho = rho - runTime.deltaT()*fvc::div(phi); ......
I checked setDelta.H, compressibleCourantNo.H which tells runTime.deltaT() as a scalar.
But I want a runtime.deltaT() as volScalarField which has delta time defined for each cell.
Can anyone help me in this regard
ramhari is offline   Reply With Quote
Old   June 16, 2011, 11:10
David Gaden
marupio is on a distinguished road
The runTime scalar is used in the fvc and fvm namespaces in the discretization process. If you want to have any of these functions work with the local time, then you are looking at a complex problem. If, on the other hand, you just want to store a "local time" field that you use independently, that would be much easier. How do you plan to use the local time?
marupio is offline   Reply With Quote
Old   June 16, 2011, 14:16
" If, on the other hand, you just want to store a "local time" field that you use independently, that would be much easier"
Exactly the second one. A false time field just to update rho,rhoU and rhoE For e.g.
rhoU = rhoU - ...
rhoE = rhoE - ...
runTime.deltaT() is very local (or which only plays around setDelta.H, readTimecontrols.H and compressibleCourantNumber.H) and nothing to do with ddt schemes I specify. (whatever ddtscheme in the fvSchemesDict)
& Hopefully, I didn't confuse you
Thanks, hari
Old   June 16, 2011, 14:43
Sandeep Menon
deepsterblue will become famous soon enough
Take a look at the SLTSDdtScheme in $(FOAM_SRC)/finiteVolume/ddtSchemes/SLTSDdtScheme
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   June 17, 2011, 04:02
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
Also, the just released new version of OpenFoam uses a local time step for their new VOF solver:
http://www.openfoam.com/version2.0.0/steady-vof.php
You might want to have a look at that.
sharonyue and Thamali like this.
akidess is offline   Reply With Quote
Old   July 6, 2011, 09:37
Dear all,
( Please check the previous posts in this thread to have an idea)
I have slightly modified the inviscid solver rhoCentralFoam in order to improve the acceleration to steady state using local time step without touching any other part (e.g. reconstruct(). - flux calculations). And it seems working for my case.
If anyone have a word/doubt in my modification please post it.
//////////Local time step - false time step
forAll (mesh.C(),i)
cell faces = mesh.cells()[i];
denom = 0.0;
forAll (faces,j)
denom = denom + ( (U[i] & mesh.Sf()[j]) + c[i]*mesh.magSf()[j] );
falseTime[i] = maxCo * mesh.V()[i] / denom;
//////// Conservation equations
// --- Solve density
rho = rho - falseTime*fvc::div(phi);
// --- Solve momentum
rhoU = rhoU - falseTime*fvc::div(phiUp);
// --- Solve energy
rhoE = rhoE - falseTime*fvc::div(phiEp);
mm.abdollahzadeh likes this.
Old   January 9, 2012, 13:49
Eric M. Tridas
eric.m.tridas is on a distinguished road
Has anyone else done this? I'm really interested in speeding up my rhoCentralFoam simulations but am having some trouble implementing it. I'd really appreciate the help anyone else can give!
Thanks,
-Eric
eric.m.tridas is offline   Reply With Quote
Old   March 25, 2012, 11:19
Ehsan
ehsan is on a distinguished road
Dear all
I need a reference which describes by more details the new local-time stepping (LTS) approach applied in VOF in openfoam.
Thanks
ehsan is offline   Reply With Quote
Old   October 7, 2012, 12:23
mahdi abdollahzadeh
mm.abdollahzadeh is on a distinguished road
Originally Posted by ramhari View Post
Dear all,
forAll (mesh.C(),i)
denom = 0.0;
forAll (faces,j)
// --- Solve energy
Dear Friend
There is one question:
the falsetime that you are calculating is the local deltaT. so its changing from cell to cell.
so its almost the same as the local euler or coeuler scheme in openfoam?
secondly this scheme is not giving unsteady result. just the final result could be correct?
How can u access the simulationtime? how you will control writting the variables according the controldict writecontrol ( considering that u have local time )
Best
Mahdi
mm.abdollahzadeh is offline   Reply With Quote
Old   September 27, 2015, 12:24
Kadu
Pravin Kadu is on a distinguished road
Dear friend,
Can you please provide the 'local time stepping' related theory.
Because I am not getting that how the cells will have different time steps, since they would be interdependent?
Thanks.
Pravin Kadu is offline   Reply With Quote
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Forces in OF15 richard OpenFOAM Running, Solving & CFD 180 July 9, 2018 10:54
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
