inlet conditions for multiphase problems
Old   July 12, 2011, 06:40
Default inlet conditions for multiphase problems
of_user_ is on a distinguished road
hi. i do have problems in a case concerning the inlet in a multiphase problem.
in my case, i have a droplet of phase2 sitting on a surface. on this surface i have a smaller patch with an inlet BC to inject more fluid of phase2 into the droplet. i simply edited the files 'alpha1' and 'U' this way:
bottomInlet
type constantAlphaContactAngle;
theta0 105;
limit gradient;
value uniform 1;
bottomInlet
type fixedValue;
value uniform (0 0 0.005);
and this works perfectly for a certain amount of time. but when the droplet is getting really large, the inlet is not inserting pure phase2 fluid anymore but a mixture of phase 1 and 2 instead.
does anybody know how to force the inlet to inject phase2 during the hole simulation time?
thank your for your help!
regards...
/edit:
it seems like this problem is just appearing for constantAlphaContactAngle. with dynamicAlphaContactAngle i do not have this phenomena.
of_user_ is offline   Reply With Quote
Old   July 13, 2011, 04:06
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi
Use constant pressure at the inlet instead of constant velocity.
ata is offline   Reply With Quote
Old   July 13, 2011, 04:32
i will try that, thank you so far!
Changing inlet conditions without starting again Conflate OpenFOAM Pre-Processing 3 April 25, 2022 08:19
Boundary conditions: inlet and outlet aline OpenFOAM 7 June 29, 2010 03:45
periodic boundary conditions at the inlet Nacho Tauste FLUENT 0 January 14, 2009 12:34
inlet boundary conditions species transport richard FLUENT 2 August 20, 2008 07:25
Problems with Inlet species San24 Siemens 1 May 7, 2008 06:29
