rhoCentralFoam linearUpwind
Like Tree6Likes
  • 1 Post By Andy_bm
  • 1 Post By vkrastev
  • 1 Post By Andy_bm
  • 2 Post By vkrastev
Old   November 14, 2011, 01:42
Default rhoCentralFoam linearUpwind
Andy_bm is on a distinguished road
Dear foamers.
I want to try the schemes linearUpwind in interpolationSchemes for rhoCentralFoam solver.
In the begining my fvSchemes file looks so:
fluxScheme Tadmor;
ddtSchemes
default Euler;
gradSchemes
  default cellLimited leastSquares 1;
divSchemes
default none;
div(tauMC) Gauss linearUpwind;
div(phi,k) Gauss linearUpwind;
div(phi,omega) Gauss linearUpwind;
laplacianSchemes
default Gauss linear corrected;
default linear;
reconstruct(rho) upwind;
reconstruct(U) upwind;
reconstruct(T) upwind;
snGradSchemes
default corrected;
Then i replace interpolationSchemes
default linear;
reconstruct(rho) linearUpwind;
reconstruct(U) linearUpwind;
reconstruct(T) linearUpwind;
and OpenFoam gives out an error:
[3] --> FOAM FATAL IO ERROR:
[3] Grad scheme not specified
Valid grad schemes are :
8
Gauss
cellLimited
cellMDLimited
extendedLeastSquares
faceLimited
faceMDLimited
fourth
leastSquares
Then i replace interpolationSchemes to
default linear;
reconstruct(rho) Gauss linearUpwind;
reconstruct(U) Gauss linearUpwind;
reconstruct(T) Gauss linearUpwind;
[17] --> FOAM FATAL IO ERROR:
[17] Unknown discretisation scheme Gauss
Valid schemes are :
51
Gamma
Gamma01
MUSCL
MUSCL01
Minmod
OSPRE
QUICK
SFCD
SuperBee
UMIST
biLinearFit
blended
clippedLinear
cubic
cubicUpwindFit
downwind
filteredLinear
filteredLinear2
filteredLinear3
fixedBlended
harmonic
limitWith
limitedCubic
limitedCubic01
limitedGamma
limitedLimitedCubic
limitedLimitedLinear
limitedLinear
limitedLinear01
limitedMUSCL
limitedVanLeer
linear
linearFit
linearPureUpwindFit
linearUpwind
localBlended
localMax
localMin
midPoint
outletStabilised
quadraticFit
quadraticLinearFit
quadraticLinearUpwindFit
quadraticUpwindFit
reverseLinear
skewCorrected
upwind
vanAlbada
vanLeer
vanLeer01
weighted
How probably to use linearUpwind?
Thanks.
febriyan91 likes this.
Andy_bm is offline   Reply With Quote
Old   November 14, 2011, 03:46
Vesselin Krastev
vkrastev is on a distinguished road
To use the linearUpwind scheme you have to specify also a gradient scheme. The correct syntax in OF-2.0.x should be (for instance):
div(phi,k) Gauss linearUpwind grad(k);
where grad(k) is the scheme specified for k in the gradSchemes section (in your case, the default cellLimited leastSquares 1 scheme will be selected).
In OF-1.7.x this syntax will not be recognized, because you have to specify explicitly the gradient scheme, like in the following example:
div(phi,k) Gauss linearUpwind cellLimited leastSquares 1;
Finally, just a note about div(tauMC): it is an explicitly calculated divergence term, not a convective flux term, thus the only scheme that makes sense is Gauss linear.
Hope this helps
V.
hua1015 likes this.
vkrastev is offline   Reply With Quote
Old   November 14, 2011, 10:11
Thanks for your fast reply,
You tip has really helped me, but i have same questions:
If i use
default linear;
reconstruct(rho) upwind cellLimited leastSquares 1;
reconstruct(U) upwind cellLimited leastSquares 1;
reconstruct(T) upwind cellLimited leastSquares 1;
What order of the scheme turns out, the first or the second?
Old   November 14, 2011, 10:30
Vesselin Krastev
If i use
default linear;
Actually this syntax makes no sense, because the first order upwind scheme does not need any gradient scheme specification (I think that the code will simply ignore anything you write after "upwind"). Anyway, I advice you to use something more accurate for the reconcstruction schemes, like for instance:
default linear;
reconstruct(rho) Gamma 1;
reconstruct(U) GammaV 1;
reconstruct(T) Gamma 1;
Regards
V.
hua1015 likes this.
Old   November 14, 2011, 10:43
I already tried to use this:
default linear;
but my case has dispersing decision
my case has the decision only
default linear;
And now I try find the scheme which will raise accuracy of the decision.
Thanks.
Old   November 14, 2011, 10:51
Vesselin Krastev
default linear;
default linear;
Thanks.
It depends from what you are looking for: rhoCentralFoam is designed as a transonic shock-capturing solver and the solution scheme of Tadmor and Kurganov is also constructed for this kind of flows, so using a first order scheme in my opinion introduces too much diffusion. I've noticed that sometimes rhoCentralFoam returns an oscillating behavior, but if you set the gradientScheme to a limited option (as for instance the cellLimited leastSquares 1 option) the oscillations are largely smeared out. It's up to you.
V.
Old   November 14, 2011, 11:02
I solve a problem of the expiration stream (М~2-5) in vacuum what solver can you recommend? I used sonicFoam, but he required too much time for the decision.
Old   November 14, 2011, 11:27
Vesselin Krastev
rhoCentralFoam is the best OF solver for this kind of flow: just play a bit with the schemes until the (eventual) oscillations will be sufficiently small for your requirements.
V.
febriyan91 and hogsonik like this.
Old   November 14, 2011, 11:34
Thanks a lot, I will try select schemes.
A few simple questions about linearUpwind and limitedLinear chegdan OpenFOAM 28 March 30, 2024 02:44
rhoCentralFoam with totalPressure/totalTemperature at inlet of subsonic channel deepblue17 OpenFOAM Running, Solving & CFD 5 February 11, 2013 02:42
localEuler in rhoCentralFoam praveen OpenFOAM 4 October 21, 2012 02:19
linearUpwind scheme in OpenFOAM 2.0.1 ??? cabul OpenFOAM 8 November 9, 2011 06:57
Always crash when solve a C-D nozzle flow field using rhoCentralFoam hawklion OpenFOAM Running, Solving & CFD 0 March 9, 2011 06:13
