[swak4Foam] time-dependent inletOutlet with groovyBC?
Old   October 29, 2013, 08:44
Default time-dependent inletOutlet with groovyBC?
Marcus Letzel
letzel is on a distinguished road
Dear Foamers,
given a measured time series of patch-normal velocity Un, is it possible with groovyBC and timelines or lookuptables to set time-dependent inletOutlet boundary conditions on that patch?
I want to set up the following scenario:
  • in case of inflow (say Un >= 0), set inflow boundary condition (value of Un uniform over patch),
  • in case of outflow (say Un < 0), set zeroGradient pressure boundary condition.
Regards,
Marcus
letzel is offline   Reply With Quote
Old   October 29, 2013, 11:08
Assistant Moderator
Bernhard Gschaider
Originally Posted by letzel View Post
Dear Foamers,
Regards,
Marcus
Yep. Assuming you have a timeline Un defined
valueExpression "-normal()*Un";
fractionExpression "Un<0 ? 0 : 1";
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 30, 2013, 02:37
Marcus Letzel
Excellent. That means the U boundary condition on that patch is done.
Follow-up question: How do I have to set the corresponding pressure boundary condition on that patch? I would expect that a similar case distinction depending on the sign of Un needs to be implemented for p.
Old   October 30, 2013, 05:18
Assistant Moderator
Bernhard Gschaider
That depends on your physics. But any switching here can be done in a similar fashion (of course you can use Un inside a pressure condition as well)
Old   November 4, 2013, 11:43
Marcus Letzel
Sorry, the description of my scenario given above was not precise. Let me try to clarify. Basically I am planning to mimick "inletOutlet", the patch field type derived from mixed (table 5.4 in OF 2.2.2 user guide) using the patch-normal velocity component Un:
  • in case of inflow (Un >= 0),
    • for pressure use zeroGradient, and
    • for U use valueExpression "-normal()*Un"
  • in case of outflow (Un < 0),
    • for pressure use fixedValue, and
    • for U use zeroGradient.
My question is how to implement this pressure boundary condition with the help of fractionExpression "Un<0 ? 0 : 1" or
fractionExpression "Un<0 ? 1 : 0".
Whether or not this pressure boundary condition will work well in this case, this will be the next question...
Old   November 4, 2013, 19:08
Assistant Moderator
Bernhard Gschaider
I'd say the second one. I'm not quite sure what your problem is: the meaning of the ?:-operator or fractionExpression. Because if you understand these two it should be quite clear
Old   December 10, 2013, 08:47
Marcus Letzel
Thank you, Bernhard, the second one worked out fine.
As a follow-up question, I should now compare this with a conditional totalPressure boundary condition in case of outflow as follows:
    • for pressure use totalPressure, and
Does the groovyBC syntax allow for this? If so, how?
Old   December 11, 2013, 15:08
Assistant Moderator
Bernhard Gschaider
U we've already got covered I think.
p shouldn't be a big problem either. The catch is that you've got to specify the total pressure as an expression. You can't use the readymade BC
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 41 August 23, 2023 02:48
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
[solidMechanics] solidMechanics gear contact in rotation nlc OpenFOAM CC Toolkits for Fluid-Structure Interaction 3 January 11, 2015 06:41
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
