Boundary conditions for a 1-d channel
Old   November 3, 2011, 04:54
Default Boundary conditions for a 1-d channel
Marco Popesso
popezmark is on a distinguished road
Hi everyone.
I'm a new Foamer and i need some advice, can you help me please?
I'm trying to run a simple 1-D simulation similar, to the shockTube tutorial, with sonicFoam solver.
I have a rectangular conduit 1d with inlet and outlet patches at the edges, and the other faces are classified "empty".
In the first phase of the simulation, I have, inside the conduit, air with low pressure and temperature, and ZERO velocity. I want to have the inlet OPEN and communicating with a high pressure and temperature air ambience. The outlet is CLOSED like a wall. So, I expect the formation of a shockwave, starting from the inlet and moving towards the outlet, and of course there will be introduction of hot air coming from the outside and passing through the open inlet, compressing the cold air that was inside the conduit. Eventually the shockwave reach the closed outlet and is reflected back.
My question is: what is the most appropriate pressure boundary condition for the inlet? I tried this:
For pressure:
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 196000; <-- I'm using Pascal
boundaryField
inlet
type totalPressure;
gamma 1.4;
p0 353000;
outlet
type zeroGradient;
empty
type empty;
for temperature:
dimensions [0 0 0 1 0 0 0];
internalField uniform 435; <--- kelvin
boundaryField
inlet
type fixedValue;
value uniform 1589;
outlet
type zeroGradient;
empty
type empty;
and for velocity:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform (0 0 0); <--- this is for the wall
empty
type empty;
Am I doing correctly?
Thank you everyone.
popezmark is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
boundary conditions in FLUENT VOF for open channel flow newcomer Fluent Multiphase 32 May 4, 2020 07:28
boundary conditions for open rectangular channel pavan FLUENT 1 March 6, 2007 15:46
