Lagrangian Solver Problem
Old   November 7, 2011, 20:28
Default Lagrangian Solver Problem
Bruce Hartley
Bruce Hartley is on a distinguished road
I have used the Lagrangian solver by setting a central potential, finding its gradient to give the force and then setting particle velocities and tracing the paths. This is esentially in two dimensions. I find that when I set a radial velocity I can trace a nice circle, as expected, with a bit of numerical round-off error giving a slightly different path the second time round. When I reverse the velocity (i.e. starting with the negative of the original velocity) the system traced a circle but with a very different radius. This should not be the case. Has anyone else found this asymmetry in tracing particles using the Lagrangian solver or with the function for finding the gradient of a potential field? Thanks.
Bruce Hartley is offline   Reply With Quote
asymmetry, errors, lagrangian solver
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
problem with developing new LES solver Edison_Ge OpenFOAM 2 June 18, 2009 01:26
Wmake problem interFoam solver feijooos OpenFOAM Running, Solving & CFD 4 December 8, 2008 11:01
Can I use coupled solver for this problem Frank FLUENT 0 April 11, 2006 06:28
