Wall contact in interTrackFoam
Old   March 5, 2009, 08:01
Default Hello, I would have liked
Virginie Ehrlacher
virginie_e is on a distinguished road
I would have liked to ask what kind of boundary condition I should set on a wall where there is a triple point (limit between my fluid and air). I would like this triple point to move naturally during the simulation. I saw in another thread that the slip condition for motionU worked if the wall was flat. But, what if it is not flat?
Thank you in advance.
Virginie
virginie_e is offline   Reply With Quote
Old   March 5, 2009, 09:45
Default I think the slip BC takes poin
Sandeep Menon
deepsterblue will become famous soon enough
I think the slip BC takes point-normal information from each patch and uses that to zero-out the forces in that direction at the motion-solver level.
If this is indeed the case, then I guess the slip boundary should work even on a non-planar wall. But I would be a little concerned if mass-conservation is a priority in your simulation - moving points on a non-planar surface tends to develop minor errors in domain-volume over time.
There's only one way to find out - try it!
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   November 8, 2011, 11:52
akidess's Avatar
Anton Kidess
Virginie, have you continued your work with interTrackFoam? If so, did you experience any problems with wall contact?
How to vary wall contact angle in the solver hsieh OpenFOAM Running, Solving & CFD 7 February 28, 2010 08:22
Wall contact angle feijooos OpenFOAM Pre-Processing 4 February 3, 2009 11:52
Wall contact angle feijooos OpenFOAM Pre-Processing 0 January 28, 2009 13:31
Moving contact line (dynamic contact angle) Pulli FLUENT 0 March 1, 2007 12:31
how to code wall contact angle? schou Main CFD Forum 2 May 5, 2003 20:50
