Is there a way to enforce my timestep?
Like Tree1Likes
  • 1 Post By kwardle
Old   November 9, 2011, 13:30
Default Is there a way to enforce my timestep?
Shawn
Shawn_A is on a distinguished road
I'm using pimpleDyMFoam to simulate a vertical axis wind turbine with a stationary outer domain and a rotating inner domain using the ggi. I would like to be able to strictly enforce my timestep. I have tried to raise my maxCo to 100 (yes, I know the implications) but the deltaT used in the solution will never go higher than 0.000556 (my desired deltaT is 0.00278 which corresponds to 1 deg rotation at 60 RPM). The maxCo in the solution is ~7.33 so it never approaches 100.
Is there another parameter I should look at to get my deltaT to where I want? Convergence doesn's seem to be an issue at this Co/deltaT (7.3/5.6e-4) yet.
Thanks,
Shawn
Shawn_A is offline   Reply With Quote
Old   November 9, 2011, 13:40
Kent Wardle
kwardle is on a distinguished road
Is there a reason you cannot simply change system/controlDict such that:
deltaT 0.00278;
adjustTimeStep no;
This should give you a constant time step.
-Kent
atg likes this.
kwardle is offline   Reply With Quote
Old   November 10, 2011, 11:53
Shawn
Wow...I guess I've been looking at this too long. That command is literally 2 lines above maxCo.
Thanks Kent!
Restart 2-way FSI with different timestep? Lance CFX 10 April 17, 2013 00:37
How to interrupt unsteady calculation and carry on without timestep increase? aleisia FLUENT 1 March 18, 2011 23:02
Adequate timestep selection for multidomain problem gerardosrez CFX 6 November 28, 2010 17:50
interTrackFoam timestep virginie_e OpenFOAM Running, Solving & CFD 4 April 6, 2009 05:02
Timestep selection Jindra Kosprdova CFX 9 April 28, 2005 06:41
