There are non-conformal cyclic bc in OF 2.0.x?
Old   November 14, 2011, 06:00
Question There are non-conformal cyclic bc in OF 2.0.x?
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Hi foamers,
I need to simulate a case with non-conformal cyclic bc (i.e. the mesh on the two sides of the cyclic interface cannot be the same). Is there any chance to do it in OF 2.0.x or the only way is to use OF-ext?
Thanks!
Ivan
ivan_cozza is offline   Reply With Quote
Old   November 15, 2011, 05:07
Laurens Van Dyck
laurensvd is on a distinguished road
Is the geometry different or the mesh? Maybe you can check into the directmappedfield boundary condition.
laurensvd is offline   Reply With Quote
Old   November 15, 2011, 05:11
Ivan Flaminio Cozza
The geometry is the same, but the mesh is not, as it is produced by an automatic mesh generator.
How does directmappedfield work?
Thanks a lot,
Ivan
Old   November 15, 2011, 05:26
Ivan Flaminio Cozza
And more, my cyclic boundaries are circular periodic.
Old   November 15, 2011, 05:34
Laurens Van Dyck
I dont know anymore exactly how it works but check the source OFdir/src/finiteVolume/fvPatchFields/derived
There are several version of this direct mapped field and inside the code you can see at the top which information they require. Basically you need to declare somewhere the patch that you want mapped on the patch that you apply the BC to. I dont know if you can do that for both your patches as to simulate a cyclic condition.
Old   November 21, 2011, 13:59
Michael Ahlmann
danishdude is on a distinguished road
Have you gotten this to work? If so, could you post the solution. Thanks,
-Michael
danishdude is offline   Reply With Quote
Old   November 24, 2011, 06:34
Ivan Flaminio Cozza
No Michael,
unfortunately it actually doesn't work, as directMapped is mono-directional, is not possible a two-way coupling. Up to now it seems that the only solution is cyclicGGI, but you have to install the ext version...
Cyclic vs ggi vs directMapped Patches jens_klostermann OpenFOAM Running, Solving & CFD 33 May 3, 2013 02:45
Cyclic bc. and overlapGgi Pekka OpenFOAM 12 February 15, 2012 07:10
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
[snappyHexMesh] snappyHexMesh with cyclic patches? Axel_T OpenFOAM Meshing & Mesh Conversion 1 October 12, 2010 10:03
Arbitrary Cyclic beta code luca OpenFOAM Running, Solving & CFD 0 June 13, 2007 10:10
