LES for urban areas
Old   February 26, 2014, 08:11
Default LES for urban areas
hydraulic is on a distinguished road
Dear all,
I plan to compute some LES simulations using OpenFOAM to study to flow field around a urban area (1km2).
I' m collecting experimental data since 1 month (3d anemometers mean+turbulence) and i would like now to run LES.
I m confused with all the models proposed by OpenFOAM, which one would you recommend me? the dynOneEqEddy is adequate?
i plan to use the cubeRootVol as the delta.
Regarding the inlet, i plan to use cyclic boundary conditions.
Regarding the mesh, i prepared one with cells 1m close to the ground/wall.
Does someone has any suggestion or tried to run LES for such case.
Thanks in advance for your help.
hydraulic is offline   Reply With Quote
LES Filtering: how are the small and large scales equations solved? atmcfd Main CFD Forum 38 March 14, 2016 14:52
Beginning to work in LES - Suggestions needed atmcfd Main CFD Forum 5 July 20, 2012 22:16
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
