Problem with rhoSimplecFoam - nan
Old   January 8, 2012, 10:51
Default Problem with rhoSimplecFoam - nan
Daniel
dancfd is on a distinguished road
Hello all,
I am trying to evolve my incompressible, steady-state 2D airfoil simulation into a compressible, steady-state simulation. I have selected rhoSimplecFoam as a solver, however I cannot get the simulation to run past 9 iterations without getting "nan" for the residuals first with k and omega, then the next iteration has residuals of "nan" for all variables. I have tried playing with the boundary conditions and solver parameters to no avail. Would someone please suggest where I could start looking? Some information:
1. The simulation runs successfully and with results that compare well to experimental data in simpleFoam;
2. The mesh is a c-grid with ~42000 cells and a boundary 10c from the NACA 0012 airfoil;
3. Angle of attack is 13 degrees, implemented by introducing a inlet velocity at that angle (mesh pic attached);
4. Boundary conditions are as attached;
5. k-omega turbulence model;
6. fvSolution & fvSchemes copied from tutorial rhoSimplecFoam\squareBend.
Thank you for any suggestions,
Dan
dancfd is offline   Reply With Quote
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
