modifying nuSgsWallFunction
Old   January 16, 2012, 21:03
Default modifying nuSgsWallFunction
Kim Yusik
impecca is on a distinguished road
Dear Foamers,
I am trying to modify the nuSgsWallFunction (nuSgsUSpaldingWallFunctionFvPatchScalarField.C) in OF 1.7.1 and I got some questions.
I want to implement Wang & Moin ( pof.aip.org/resource/1/phfle6/v14/i7/p2043_s1 ) model. In this model it specifies tauw (wall shear stress) directly rather than nuSgs (like in 'nuSgsWallFunction'). So I managed to acess to the 'tauw' (B() in LES model, see the code below) as a first step but I do not know how I return a calculated values into the B().
I just added few more lines within the nuSgsUSpaldingWallFunctionFvPatchScalarField.C file.
// * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * //
void nuSgsWallFunctionFvPatchScalarField::evaluate
const Pstream::commsTypes
const scalarField& ry = patch().deltaCoeffs();
const fvPatchVectorField& U =
patch().lookupPatchField<volVectorField, vector>(UName_);
scalarField magUp = mag(U.patchInternalField() - U);
const scalarField& nuw =
patch().lookupPatchField<volScalarField, scalar>(nuName_);
//*** modification
const label patchI = patch().index();
const LESModel& lesModel =db().lookupObject<LESModel>("LESProperties");
fvPatchSymmTensorField& tauw= lesModel.B()().boundaryField()[patchI];
forAll(tauw, facei){
tauw[facei]=symmTensor(0.0, 0.0, 0.0, 0.0, 0.0, 0.0);
//*** modification END
By this way, I got an error when I run a simulation which is
#0 Foam::error:: printStack(Foam::Ostream&)
It seems that 'tauw[facei]=symmTensor(0.0, 0.0, 0.0, 0.0, 0.0, 0.0)' has a problem. without this line, no error.
So could you suggest me how to return the calculated 'tauw' values into B() please? or any suggestion will be appreciated.
Thanks in advance.
Yusik
impecca is offline   Reply With Quote
Modifying the laplacian operator mlawson OpenFOAM Running, Solving & CFD 22 July 16, 2018 04:56
nuSgsWallFunction in parallel cfdmarkus OpenFOAM Bugs 1 October 8, 2009 10:09
modifying Prepin File from command line pgopalak FLOW-3D 1 August 5, 2009 11:06
Suggestion for Modifying the Standard k-e Model Iaroslav FLUENT 0 June 9, 2009 11:01
modifying commercial codes Richard Carroni Main CFD Forum 1 October 15, 1998 06:38
