Porous panel for airflow over a radiator with simpleFoam?
Old   May 14, 2012, 01:11
Default Porous panel for airflow over a radiator with simpleFoam?
Doug68 is on a distinguished road
Hi All,
I’m running aerodynamic simulations on a scratch designed – built car, one of the areas of interest to me is the airflow through the radiator and what’s happening in the ducting leading to the radiator and where the air is going after passing through it and so on.
At the moment the complete car with radiator is a single stl file. The radiator is modelled reasonably realistically from measurements taken from the real thing. However getting a realistic mesh created using snappyhexmesh is proving difficult and frankly I’m sure that I’m not going about this in the right way.
What I think I should be doing is defining the radiator as a porous panel in some way, the caveat being that as it’s a radiator the flow needs to pass through it normal to the surface.
Does this sound like the correct approach? If so could someone point me at an example of such a thing?
BTW I’m pretty happy just have got to this stage, being able to get to the point where I can move onto tackling the next level of detail seems a long way from where I started a month or two ago.
Thanks.
Doug68 is offline   Reply With Quote
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
Direction vector in porous media panel Claud FLUENT 0 March 15, 2007 05:04
How to define c0 and c1in porous panel??? *NM* rati FLUENT 0 June 28, 2006 03:04
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
