OpenFOAM v.2.x Courant Number 4 time higher then in previous versions
Like Tree2Likes
  • 1 Post By makaveli_lcf
Old   February 16, 2012, 04:57
Default OpenFOAM v.2.x Courant Number 4 time higher then in previous versions
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Hi Foamers!
I got and issue using OpenFOAM v2.x:
Courant Number jumps 4 times if compare to OpenFOAM v1.6 and 1.7.x.
I tried cases for different geometries ofcouse with the same setting between OF versions and result is always the same!
Actually this issue results in a calculation time increasing 4 times. Unappropriated!
Please, comment on that issue, what is your experience with v2.x usage?
Cheer,
Alex
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   February 16, 2012, 07:54
Reported at Mantis:
http://www.openfoam.com/mantisbt/view.php?id=424
Best regards,
Old   February 16, 2012, 09:05
Issue closed (http://www.openfoam.com/mantisbt/view.php?id=424#c1039):
The method for calculating the Courant number has been changed since version 1.7.x to be better represent the stability requirement of collocated meshes. In general the change hase resulted in slightly lower values.
A change in the method to calculate the Courant number does not in itself change the stability of the algorithm or lead to divergence as it is not used in the algorithm; only to set the time-step. If you have a case which behaved differently for the same fixed time-step between different versions of OpenFOAM the issue does not relate to a change in the way in which the Courant number is calculated.
So then it means that OF 2.x is less stable with the same fixed time step...
Will do more checks and report regarding actual calculation time.
chegdan likes this.
Best regards,
Old   February 17, 2012, 11:02
Alberto Passalacqua
What solver? I was aware of the change in the definition of Co, which was made to remove inconsistency at boundaries, but I haven't experienced major issues with 2.1.x.
Alberto Passalacqua
Old   February 17, 2012, 15:20
Hi Alberto!
pimpleFoam. According to my test to keep the same Co number (with which solution does not diverge) actual calculation time increased 2 times (I remind with the same constant dt I've got Co_new_OF = 4*Co_old_OF).
Best regards,
Old   February 17, 2012, 15:22
Slow down, to my opinion, is not 4 times because now turbulence is solved at last PIMPLE iteration. But of course I tried with turbulence updated each iteration: the same result, solution diverges with the dt I used before with old OF versions..
anmartin likes this.
Best regards,
Old   February 17, 2012, 21:14
Alberto Passalacqua
OK, let's try to do some troubleshooting, if you like
Do you use any particular boundary condition? For example mapped, or time-varying, or custom BC? Some of these were updated in 2.x.
Alberto Passalacqua
Old   February 18, 2012, 06:55
Nope, standard k-epsilon (also tried with realizable which I mostly use) with standard wall functions for k, epsilon, nut, fixed values for U at inlet and zero gradient at outlet, pressure 0 at outlet and zero gradient at the inlet. I think it would be better if I upload here some test case. Will do it on Monday.
Best regards,
Old   February 18, 2012, 21:28
Alberto Passalacqua
Yes, that's a good idea. The BC's are surely not the reason.
Alberto Passalacqua
courant number, openfoam
Very high courant number, time step continuity errors and bounding epsilon erncyc OpenFOAM Running, Solving & CFD 1 March 24, 2011 11:00
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
