Road emission source term
Old   March 15, 2012, 12:41
Default Road emission source term
Robert S Hahn
rhahn is on a distinguished road
I am attempting to add a road emission source term, which I would like to specify geometrically using pos().x, pos().y, and pos().z. I use the following CSourceDict and get a run-time parsing error. Does anyone have experience doing this or an easier way?
| \\ / O peration | Version: 2.0.0 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object CSourceDict;
variables ("where=0;" // Quantity introduced into the domain per second
// Source of Volume
"x1=597000.0;"
"x2=597010.0;"
"x3=597110.0;"
"x4=597100.0;"
"y1=4167510.0;"
"y2=4167700.0;"
"y3=4167700.0;"
"y4=4167510.0;"
"zmin1=0;"
"zmax1=5;"
"zmin2=0;"
"zmax2=5;"
"rate1=1;"
"Volume1=10000;"
"where=((((pos().y >= y1 && pos().y < y4) || (pos().y >= y4 && pos().y < y1)) && (pos().x < (x4 - x1) * (pos().y-y1)/(y4 - y1) + x1)) || (((pos().y >= y2 && pos().y < y1) || (pos().y >= y1 && pos().y < y2)) && (pos().x < (x1 - x2) * (pos().y - y2)/(y1 - y2) + x2)) || (((pos().y >= y3 && pos().y < y2) || (pos().y >= y2 && pos().y < y3)) && (pos().x < (x2 - x3) * (pos().y - y3)/(y2 - y3) + x3)) || (((pos().y >= y4 && pos().y < y3) || (pos().y >= y3 && pos().y < y4)) && (pos().x < (x3 - x4) * (pos().y - y4)/(y3 - y4) + x4))) ? 1 : where;"
expression "(rate1/Volume1)*where";
dimensions [0 0 -1 0 0 0 0];
rhahn is offline   Reply With Quote
Old   March 15, 2012, 14:59
Assistant Moderator
Bernhard Gschaider
FoamFile
version 2.0;
format ascii;
class dictionary;
object CSourceDict;
// Source of Volume
"x1=597000.0;"
"x2=597010.0;"
"x3=597110.0;"
"x4=597100.0;"
"y1=4167510.0;"
"y2=4167700.0;"
"y3=4167700.0;"
"y4=4167510.0;"
"zmin1=0;"
"zmax1=5;"
"zmin2=0;"
"zmax2=5;"
"rate1=1;"
"Volume1=10000;"
You're using an expressionSource for this? (the syntax looks swakIsh)
Well. The expression for where looks impressive. First question: why don't you use 0 instead of where on the right hand side?
I wouldn't want to debug the whole expression. If I understand it correctly the parts are the road sections. One thing to make it easier would be to break up the expression into something like
"section1=(pos().x> ......;"
"section2=( ......"
and then put it together
"where=(section1 || section2 || ...) ? 1 : 0;"
Not 100% sure which fields what logical expressions accept as inputs so you might have to write it as
"where=(section1>0 || section2>0 || ...) ? 1 : 0;"
Anyway. The most elegant solution to your problem would be if you grid generation process allows you to specify cellZones or cellSets (in this example named "road") and have an expression
"where=zone(road) ? 1 : 0;"
or
"where=set(road) ? 1 : 0;"
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
