Restart using different boundary conditions
Old   March 12, 2012, 16:57
Default Restart using different boundary conditions
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi all,
what is the best way if I want to restart the simulation but I have new BC types and values? mapping or can I change it in the results file? I have 15M cells so opening a result file is not so straightforward :P
Best,
I am doing CFD Consulting Services.
Ich biete CFD Strömungssimulationen an.
Attesz is offline   Reply With Quote
Old   March 13, 2012, 01:58
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi.
As you said either you map or you use some clever sed/regex that does search and replace in the result files.
Sed would probably be faster since mapping 15M cells can take quite some time.
Best
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   March 13, 2012, 04:29
Martin
MartinB will become famous soon enough
the "changeDictionary" utility with an appropriate changeDictionaryDict might be a good choice, too.
Martin
MartinB is offline   Reply With Quote
Old   March 13, 2012, 04:35
Attesz's Avatar
Attesz
Thank you all! I'll have a look at the changeDictionary utility!
Best regards,
Attila
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
restart after changing boundary conditions aperrone STAR-CD 5 April 25, 2011 20:53
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
