k-omega SST for wall-resolved TBL, problem with log layer.
Like Tree8Likes
Old   March 13, 2012, 07:51
Default k-omega SST for wall-resolved TBL, problem with log layer.
Guillaume Terlinden
mevoili is on a distinguished road
Hello Foamers,
I'm trying to compute a turbulent flow on a 2-D airfoil usin RANS. I've created my mesh such that the flow is wall resolved (y+ ~ 1 ). I would like to compare different models: the first one is the Spalart-Allmaras model, and the second one is the k-omega SST model. From what I've read, those two models are good for wall-resolved turbulent flow, and especially for boundary layers experiencing adverse pressure gradients, and separating flows.
To be sure about the quality of my results, I have first computed a simple turbulent boundary layer on a plane plate, with an uniform velocity at the inflow. For the Spalart-Allmaras model, the results are very good and show the expected viscous layer and the log layer, but for the k-Omega SST model, the results aren't that good (See picture), and there is no log layer (or at least with the correct slope kappa ~ .37), and I don't know where that problem might come from (i used pisoFoam solver)...
For the boundary conditions on omega, I use the condition :
omega_wall = 10*6*nu/0.075*y^2 with y = distance to the wall of the centroid of the first cell.
mevoili is offline   Reply With Quote
Old   March 13, 2012, 08:07
Gilles De Neyer
gdeneyer is on a distinguished road
I had the same problem a few weeks ago. I would be really happy if somebody had the solution !
Which inflow/outflow condition did you use for k and omega ?
gdeneyer is offline   Reply With Quote
Old   March 13, 2012, 08:16
Felix L.
FelixL is on a distinguished road
Hello, Guillaume,
this doesn't look right. I had better results for such a simple case using the k-omega-SST-turbulence model. Can you give us more infos on your setup? (grid specs, numerical schemes, boundary conditions, initial conditions)
Greetings,
Felix
FelixL is offline   Reply With Quote
Old   March 13, 2012, 12:27
Guillaume Terlinden
Here are my boundary and initial conditions :
inlet :
k = 1e-4;
omega = 1;
nut : calculated;
U = (1 0 0);
p : zeroGradient;
outlet :
k : zeroGradient
omega : zeroGradient;
nut : calculated;
U : zeroGradient;
p = 0;
wall :
U = (0 0 0);
p = zeroGradient;
k : zeroGradient;
omega = 10*6*nu/0.075*y^2 with y = 2.3e-4 and nu = 1e-5
nut = 0;
Initial condition : omega = 1; k = 1e-4 ; p = 0; U = (1 0 0);
I think my grid is okay since the Spalart Allmaras works well on it..
Thanks for your help
Old   March 13, 2012, 12:33
Guillaume Terlinden
And here are my fvSolution & fvSchemes, but I don't think the problem comes from there...
fvSolution
|  \\    /   O peration     | Version:  2.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver              GAMG;
        preconditioner         DICGaussSeidel;
        tolerance           1e-06;
        relTol              0.0001;
    nCellsInCoarsestLevel   100;
    agglomerator         faceAreaPair;
    mergeLevels        1;
    smoother        GaussSeidel;
    nPreSweeps        0;
    nPostSweeps        2;
    nFinestSweeps        2;
       pFinal
        solver              GAMG;
        tolerance           1e-06;
        relTol              0;
    mergeLevels        1;
    nPreSweeps        0;
    nPostSweeps        2;
    nFinestSweeps        2;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-05;
        relTol          0;
    k
        solver          PBiCG;
        tolerance       1e-05;
        relTol          0;
    omega
        solver          PBiCG;
        tolerance       1e-05;
        relTol          0;
    R
        solver          PBiCG;
        tolerance       1e-05;
        relTol          0;
potentialFlow
    nNonOrthogonalCorrectors 3;
PISO
    pRefCell        10;
    pRefValue       0;
    residualControl
        p               1e-8;
        U               1e-8;
        "(k|epsilon|omega)" 1e-3;
relaxationFactors
    p               0.3;
    U               0.7;
    k               0.7;
    omega           0.7;
fvSchemes
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         backward;
gradSchemes
    default         Gauss linear;
    grad(p)         leastSquares;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss limitedLinearV 1;
    div(phi,k)      Gauss limitedLinear 1;
    div(phi,omega) Gauss limitedLinear 1;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(1,p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DomegaEff,omega) Gauss linear corrected;
    laplacian(DREff,R) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
Old   March 13, 2012, 12:44
Felix L.
Hello, Guillaume,
thanks for the informations. For a start, I have two comments:
1. Use k = fixedValue 1e-12 (or some different, very small number) at the wall. zeroGradient usually is the wall function approach. In LowRe-formulations, k equals zero at the wall.
2. Your solution doesn't seem to be converged. Could you attach a residuals vs. time plot, please? Using simpleFoam (steady-state calculations) there were problems with the omega equation not being solved anymore after some iterations. This lead to wrong results. It can be the same in your case. I'd suggest to set the solver tolerance for omega to a very small value (1e-12, for example) and try again.
Greetings,
Felix.
Old   March 13, 2012, 13:01
Guillaume Terlinden
Thanks for your advices, Felix, I will try to do so as soon as I can, and I will comment my results here.
Old   March 15, 2012, 05:45
Guillaume Terlinden
Hella again,
I followed your advices, and my results are better than before, but I still don't get the right logarithmic slope in the log layer..
Do you have any ideas what could cause this ?
Old   March 15, 2012, 07:23
Felix L.
Hello, Guillaume,
a.) which OF Version are you using?
b.) did you check for grid independence when using the k-Omega-SST-model?
Greetings,
Felix.
Old   March 15, 2012, 08:19
Guillaume Terlinden
I'm using openFOAM 2.0.1. What do you mean by "checking for grid independence", my omega BC at the wall depends on the first cell so I'm not sure to understand what you mean? My mesh is such that the first cell is at y+ < 1, if that's the question...
Thanks
Guillaume
Old   March 15, 2012, 08:57
Felix L.
Hello, Guillaume,
with checking for grid independence I mean that you made sure that the discretization error is low enough to omit it when interpreting your results. When grid spacing tends to zero, the discretization error also does so the easiest way to check for grid independence is to refine the mesh by factor two in all (relevant) spatial dimensions.
This does not mean that a reasonably low y+ value is enough for your results to be accurate! There are many factors playing a role in wall bounded flows, e.g. cell expansion ratio, grid density in streamwise direction, aspect ratios, etc. That's why I want to know if your results are grid independent. Otherwise it's too hard to tell why your results are so off.
Greetings,
Felix.
Old   March 15, 2012, 09:00
Guillaume Terlinden
I'll run a case on a finer mesh to compare results, but i used rather conventional values to generate my mesh so it should be ok...
Old   June 29, 2012, 08:22
Anne Gerdes
Anne Lincke is on a distinguished road
Hey,
why don't you use omegaWallFunction for omega at the wall?
Regards
Anne
Anne Lincke is offline   Reply With Quote
Old   July 10, 2012, 18:08
Guillaume Terlinden
Because I've created my mesh such that it is wall resolved (y+ ~ 1 ), in order to see all the detail of the boundary layer. Indeed, I want to study boundary layers, so using wall functions would be a non-sense
Old   July 10, 2012, 21:31
Travis Carrigan
tcarrigan is on a distinguished road
The k-omega SST turbulence model implemented in OpenFOAM is in high-Re form. There are several posts on the forums discussing the models breakdown or inaccuracy for resolved grids (y+=1).
However, I've read that you can use this model for resolved flows by coupling it with a continuous wall function like nutUSpaldingWallFunction. You would then use kqRWallFunction for k and omegaWallFunction for omega.
I've tried the above approach for turbulent flat plate flow with no success.
tcarrigan is offline   Reply With Quote
Old   July 11, 2012, 02:58
Felix L.
Hello Guillaume,
I wouldn't say it's "nonsense". The omegaWallFunction works perfectly fine for both LowRe and HighRe-meshes. Take a look at the implementation or numerous other threads in this message board and you will see that for the viscous sublayer the correct asymptotic solution is used.
@tcarrigan: You should use typical LowRe-BCs when resolving the boundary layer with your mesh. I.E. U = 0; k = 1e-12; omega = omegaWallFunction; nut = calculated or nut = 1e-12
I've used these settings with lots of success for simple flat plate cases.
Another note: if you compare the OpenFOAM implementation of the SST-model with literature you'll notice that the OpenFOAM implementation doesn't differ from typical versions of the model. Since Menter's original formulations are applicable for both cases (HighRe and LowRe), OpenFOAMs implementation also is.
Greetings
Felix
Blanco, kiddmax, JR22 and 5 others like this.
Old   July 11, 2012, 09:44
Travis Carrigan
Maybe it depends on which version of OpenFOAM you're running, Extend or OpenCFD. The break down of k-omega SST for high resolution grids was logged as a bug a while back because users assumed the implementation of the model was similar to Menter's formulation...which it was not. In that case, the model would be applicable, like you said, for both high-Re and low-Re flows without the need for wall functions.
Here is Henry's reply to the bug that was logged against 1.7.x:
http://www.openfoam.org/mantisbt/view.php?id=179#c351
If this has been addressed in 2.1, I'd like to know.
Old   July 11, 2012, 09:59
Felix L.
Hello Travis,
please refer to this post by the bug report author: http://www.cfd-online.com/Forums/ope...tml#post369671
As you can see, this issue is not directly connected with the SST-model implementation. It's more likely caused by the general numerics of OpenFOAM and it's sensitivity to smooth meshes. So yes, you are able to get accurate results on LowRe-meshes with the SST model, but you have to ensure your grid is smooth enough (this improves the stability and accuracy anyway).
I say it again: this issue is caused by grid irregularities not the SST model implementation itself.
Hope I could clarify this!
Greetings
Felix
Old   October 16, 2012, 07:46
aerogt3 is on a distinguished road
I am a bit lost here with what looks like two conflicting suggestions. If I have a y+1 mesh, and I want to fully resolve the BL (no wall fcns), should I set k = 1e-XX and nut = 1e-XX, or k = kwRWallFunction, with nut set to nutUSpaldingWallFunction?
aerogt3 is offline   Reply With Quote
Old   February 2, 2014, 17:51
Ye Zhang
kiddmax is on a distinguished road
Hi Guillaume
I have the same problem, did you solve this problem?
Best regards,
Ye
kiddmax is offline   Reply With Quote
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 00:35
[snappyHexMesh] snappy hangs while layer generation bastil OpenFOAM Meshing & Mesh Conversion 3 October 29, 2010 07:19
problem with boundary layer Bharath Main CFD Forum 1 July 11, 2008 09:06
GAMBIT problem with 3D Boundary Layer when meshing Anthony Haroutunian FLUENT 2 March 26, 2008 02:02
problem in convergence with the prism layer genera rakesh CFX 3 September 18, 2006 10:13
