AMI turbine application
Old   January 19, 2012, 09:20
Default AMI turbine application
RDG
onyir is on a distinguished road
Hi all,
I was wondering if it is possible to define a case with AMI patches, like the one on the propeller tutorial, where the rotational velocity is calculated.
Much like a turbine, where the angular velocity depends on the velocity of the flow.
Thanks in advance.
onyir is offline   Reply With Quote
Old   March 21, 2012, 04:56
Elia Daniele
fakekarma is on a distinguished road
Hallo Onyir,
I have tried simply to use instead of the "rotatingMotion" contained in the tutorial (tutorials/incompressible/pimpleDyMFoam/propeller) under constant/dynamicMeshDict, the keyword "oscillatingRotatingMotion".
As indicated in the source files "oscillatingRotatingMotion.C" and "oscillatingRotatingMotion.H" one should use within dynamicMeshDict the following:
oscillatingRotatingMotionCoeffs
CofG (0 0 0);
amplitude (0 10 0); // deg
omega 628; // rad/s
instead of the one provided within the tutorial:
rotatingMotionCoeffs
CofG (0 0 0);
radialVelocity (0 9000 0); // deg/s
At least in this way the simulation for me starts without any problem up to a point when diverges on turbulent quantities. I will try with some different settings (e.g. maxCo) to see if I can overcome this problem.
Hope it helps,
Elia
fakekarma is offline   Reply With Quote
Old   March 21, 2012, 05:40
Elia Daniele
Hallo again,
I've tried with a simpler model also contained in the tutorials (tutorials/incompressible/pimpleDyMFoam/mixerVesselAMI2D), and with the little modifications to dynamicMeshDict it works fine.
I can not attach the folder from one can run the case, since it is a bit bigger than the forum upload file limit. If you need it send me an email.
Hope it helps,
Elia
Old   March 21, 2012, 05:59
RDG
Thank you for your interest fakekarma, but what I want to achieve is that the motion of the turbine is driven by the flux, more like the tutorial of moving wing, not by specified rotational speed.
Regards,
Ricardo.
Old   March 21, 2012, 06:22
Elia Daniele
Hallo Onyir,
I can not understand if you need your body to react to the flow (like in a 6DOF simulation) or just have a variable speed based on some probes for velocity.
In the last case you could modify the source to accept an input for the omega instead of a fixed value.
Cheers,
Elia
Old   March 21, 2012, 07:46
RDG
I need my body to react to the flow, like a 6DOF simulation.
Sorry if my description was not clear.
Old   March 21, 2012, 07:59
Elia Daniele
Hallo Onyir,
as far as I now, the 6DOF capability is implemented in OF 1.6-ext, where user can set inertia, spring and damping parameters, that would be used in connection with the force and moments to etabilish the motion of the body. I've taken just a very rapid look to OF 2.1.0 and it seems to be no more present.
Good luck,
Elia
Problem with torque output from a turbine simulation. pa-dundas FLUENT 5 July 17, 2022 05:27
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
Application of periodic boundary conditions to 2 bladed wind turbine eoinsturbine3 FLUENT 0 June 8, 2011 10:13
CFX application to radial inflow gas turbine Chetan Mistry CFX 5 June 2, 2007 13:13
