sprayFoam crashes
Old   April 11, 2012, 06:15
Default sprayFoam crashes
Lukas Fischer
lukasfischer is on a distinguished road
hi forum users,
i am trying to model a nebulizer by injecting a spray source in a gas flow. my simulation crashes randomly while solving the cloud, i think the cause is that single parcels become colder than the temperature set as TMin=... in constantProperties in sprayCloudProperties.
when i restart the simulation it will continue, probably because of the small initial timestep in controlDict.
do you think that this could be the right explaination, if yes, is there a way to control the time step like with the maxCo number, but for the termal calculation of the cloud? Or could i set dummy thermal properties for the H2O
to do nothing or at least to not cause a FPE?
attached is a plot of the last timestep, the parcels are colored by temp, one of the spheres is at 150K which is the value i set as TMin. the slice is colored by pressure.
thanks, Lukas
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 9.48149e-10, global = 1.20385e-11, cumulative = 1.17464e-08
DILUPBiCG:  Solving for epsilon, Initial residual = 1.06239e-05, Final residual = 4.85898e-07, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 1.54945e-05, Final residual = 1.11891e-06, No Iterations 1
ExecutionTime = 806.61 s  ClockTime = 916 s
Courant Number mean: 0.0209411 max: 0.599903
deltaT = 0.000481764
Time = 2.85017
Solving cloud sprayCloud
--> Cloud: sprayCloud
    Added 10 new parcels
Cloud: sprayCloud
    Current number of parcels       = 687
    Current mass in system          = 3.27202e-09
    Linear momentum                 = (1.2832e-12 3.82908e-12 1.3838e-10)
   |Linear momentum|                = 1.38439e-10
    Linear kinetic energy           = 2.35283e-11
    Rotational kinetic energy       = 0
    Total number of parcels added   = 66196
    Total mass introduced           = 6.15151e-07
    Parcel fates:
      - escape                      = 0, 0
      - stick                       = 0, 0
    Mass transfer phase change      = 3.88596e-07
    D32 (mu)                        = 9.88594
    Liquid penetration 95% mass (m) = 0.0168679
DILUPBiCG:  Solving for Ux, Initial residual = 0.000911625, Final residual = 2.26302e-06, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 0.000594203, Final residual = 5.52574e-06, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.000514736, Final residual = 2.54549e-06, No Iterations 3
DILUPBiCG:  Solving for C7H16, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for O2, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for CO2, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for H2O, Initial residual = 0.000472812, Final residual = 6.91721e-06, No Iterations 2
DILUPBiCG:  Solving for hs, Initial residual = 0.000381923, Final residual = 3.39677e-06, No Iterations 3
T gas min/max   = 322.537, 370
DICPCG:  Solving for p, Initial residual = 0.00858937, Final residual = 0.000689481, No Iterations 74
DICPCG:  Solving for p, Initial residual = 0.00152945, Final residual = 0.000148412, No Iterations 7
DICPCG:  Solving for p, Initial residual = 0.000221837, Final residual = 2.20728e-05, No Iterations 10
DICPCG:  Solving for p, Initial residual = 3.29432e-05, Final residual = 2.72098e-06, No Iterations 70
DICPCG:  Solving for p, Initial residual = 4.25008e-06, Final residual = 9.68375e-07, No Iterations 4
time step continuity errors : sum local = 1.49365e-09, global = -1.20547e-11, cumulative = 1.17344e-08
DICPCG:  Solving for p, Initial residual = 0.00196189, Final residual = 0.000190001, No Iterations 26
DICPCG:  Solving for p, Initial residual = 0.00049205, Final residual = 4.17605e-05, No Iterations 59
DICPCG:  Solving for p, Initial residual = 7.16986e-05, Final residual = 6.93027e-06, No Iterations 19
DICPCG:  Solving for p, Initial residual = 1.03981e-05, Final residual = 1.03773e-06, No Iterations 14
DICPCG:  Solving for p, Initial residual = 1.55307e-06, Final residual = 8.79028e-07, No Iterations 1
time step continuity errors : sum local = 1.35458e-09, global = -6.85588e-10, cumulative = 1.10488e-08
DICPCG:  Solving for p, Initial residual = 0.000217007, Final residual = 2.06744e-05, No Iterations 12
DICPCG:  Solving for p, Initial residual = 3.76131e-05, Final residual = 2.93503e-06, No Iterations 71
DICPCG:  Solving for p, Initial residual = 4.70404e-06, Final residual = 9.41462e-07, No Iterations 4
DICPCG:  Solving for p, Initial residual = 1.03837e-06, Final residual = 7.77936e-07, No Iterations 1
DICPCG:  Solving for p, Initial residual = 7.8544e-07, Final residual = 7.8544e-07, No Iterations 0
time step continuity errors : sum local = 1.21031e-09, global = -1.17959e-11, cumulative = 1.1037e-08
DICPCG:  Solving for p, Initial residual = 4.69634e-05, Final residual = 4.51442e-06, No Iterations 17
DICPCG:  Solving for p, Initial residual = 7.84907e-06, Final residual = 9.82477e-07, No Iterations 65
DICPCG:  Solving for p, Initial residual = 1.31751e-06, Final residual = 6.55612e-07, No Iterations 1
DICPCG:  Solving for p, Initial residual = 6.63309e-07, Final residual = 6.63309e-07, No Iterations 0
time step continuity errors : sum local = 1.02209e-09, global = 2.36106e-11, cumulative = 1.10606e-08
DILUPBiCG:  Solving for epsilon, Initial residual = 1.15936e-05, Final residual = 4.86978e-07, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 1.76057e-05, Final residual = 1.14782e-06, No Iterations 1
ExecutionTime = 806.99 s  ClockTime = 916 s
Courant Number mean: 0.0209503 max: 0.600233
deltaT = 0.000481576
Time = 2.85065
    Added 16 new parcels
[3] #0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #2   in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #3  Foam::H2O::D(double, double, double) const in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libliquidProperties.so"
[3] #4
[3]  in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/sprayFoam"
[3] #5
[3] #6
[3] #7
[3] #8
[3] #9
[3] #10
[3] #11  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #12
[lukas-laptop:02279] *** Process received signal ***
[lukas-laptop:02279] Signal: Floating point exception (8)
[lukas-laptop:02279] Signal code:  (-6)
[lukas-laptop:02279] Failing at address: 0x3e8000008e7
[lukas-laptop:02279] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x33d80) [0x7f2c47a0cd80]
[lukas-laptop:02279] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f2c47a0cd05]
[lukas-laptop:02279] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x33d80) [0x7f2c47a0cd80]
[lukas-laptop:02279] [ 3] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libliquidProperties.so(_ZNK4Foam3H2O1DEddd+0x2a) [0x7f2c4ad9c7ea]
[lukas-laptop:02279] [ 4] sprayFoam() [0x479f4d]
[lukas-laptop:02279] [ 5] sprayFoam() [0x4a582e]
[lukas-laptop:02279] [ 6] sprayFoam() [0x4a5f30]
[lukas-laptop:02279] [ 7] sprayFoam() [0x4a710f]
[lukas-laptop:02279] [ 8] sprayFoam() [0x4a7de1]
[lukas-laptop:02279] [ 9] sprayFoam() [0x4a89a3]
[lukas-laptop:02279] [10] sprayFoam() [0x431558]
[lukas-laptop:02279] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xff) [0x7f2c479f7eff]
[lukas-laptop:02279] [12] sprayFoam() [0x424d89]
[lukas-laptop:02279] *** End of error message ***
mpirun noticed that process rank 3 with PID 2279 on node lukas-laptop exited on signal 8 (Floating point exception).
lukasfischer is offline   Reply With Quote
Old   May 10, 2012, 08:34
MPJ
Oliver Pasqual
MPJ is on a distinguished road
Originally Posted by lukasfischer View Post
hi forum users,
thanks, Lukas
Time = 2.85017
Cloud: sprayCloud
    Parcel fates:
      - escape                      = 0, 0
      - stick                       = 0, 0
    D32 (mu)                        = 9.88594
Time = 2.85065
[3] #4
[3] #5
[3] #6
[3] #7
[3] #8
[3] #9
[3] #10
[3] #12
Hi Lukas,
have you solved your problem?
The similar problem occured to me.
The error message is shown as:
Starting time loop
Courant Number mean: 0 max: 0
Time = 1e-05
Solving cloud coalCloud1
--> Cloud: coalCloud1
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/oliver/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/home/oliver/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
at sigaction.c:0
#3 Foam::H2O:(double, double, double) const in "/home/oliver/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libliquidProperties.so"
The case is modified from the original one, and only mesh was changed.....
so it will be highly appreciated if you can give me some suggestions on this problem.
Best regards.
oliver
MPJ is offline   Reply With Quote
Old   July 12, 2013, 23:14
Joyal
s1300044 is on a distinguished road
Hi, Lukas,
I would like to simulate a system like nebulier. Could you tell me some comments to setup the model and phycisic model in StarCCM+?
Please provide any information to me.
Thanks.
Joyal
s1300044 is offline   Reply With Quote
Old   July 14, 2013, 11:08
Lukas Fischer
Originally Posted by s1300044 View Post
Hi, Lukas,
Thanks.
Joyal
Sorry, but i only used OpenFOAM to model this. btw, a video of the final simulation is at http://www.youtube.com/watch?v=Ilme9QHcKFc
reactingFoam crashes mysteriously jose_rodrig OpenFOAM Running, Solving & CFD 9 August 4, 2015 10:18
modified code crashes in parallel mabinty OpenFOAM Programming & Development 2 January 11, 2013 05:15
checkMesh and decomposePar crashes with salome IDEAS mesh pajofego OpenFOAM 0 June 23, 2011 08:43
[OpenFOAM] paraFoam crashes with channelFoam example mgdenno ParaView 2 February 5, 2011 07:46
TwoPhaseEulerFoam bed tutorial case crashes in 1.6. Stable in 1.5 hemph OpenFOAM Bugs 2 February 17, 2010 08:10
