Time step continuity error on restart
Old   August 23, 2010, 07:53
Default Time step continuity error on restart
akidess's Avatar
Anton Kidess
Hello everybody,
I have a solver I developed based on interFoam (1.6.x). It works like a charm running from t=0, but if I try to restart a simulation at an arbitrary t!=0 I get a time step continuity error. Any idea how to fix this? I already tried changing the 'writePrecision' in controlDict from 6 to 10, but that didn't help.
- Anton
time step continuity errors : sum local = 6.660168758e-11, global = 6.639932847e-11, cumulative = 6.639932847e-11
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux              : 1.43477e-07
Specified mass inflow   : 1.17455e-13
Specified mass outflow  : 2.17053e-13
Adjustable mass outflow : 0
Old   August 23, 2010, 08:40
akidess's Avatar
Anton Kidess
I forgot to mention that this happens right after reading the transport properties, ie. before any computations are done. Also, all boundary conditions for U are fixedValue 0, and for p are zeroGradient.
Now I noticed the solver is unhappy with the call to adjustPhi in correctPhi.H using pCorr. If I remove the include for correctPhi.H, the solver seems to run as it should, but I don't really understand why this breaks things... Can anyone provide an insight if it is safe to remove this initialization?
Old   August 15, 2012, 19:05
Anonymous
Tiffany is on a distinguished road
I'm getting this exact same error. Did you figure out how to fix this???
Tiffany is offline   Reply With Quote
Old   August 16, 2012, 02:38
akidess's Avatar
Anton Kidess
A possible fix is already mentioned in my post #2.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   August 16, 2012, 11:50
Anonymous
Sorry, I meant did you find a way to fix this error without editing the solver (i.e. removing the include for correctPhi.H)? I'm getting this error when trying to run interFoam and don't want to attempt to edit the solver to run my case for obvious reasons. I'm wondering what setting(s) I can change to get this to work for me.
Old   August 17, 2012, 01:54
akidess's Avatar
Anton Kidess
Unfortunately that's the only solution I found.
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
time step continuity error, fvScheme achinta OpenFOAM 24 May 20, 2010 03:08
time step continuity errors robingilbert OpenFOAM Running, Solving & CFD 1 January 19, 2010 13:05
interDyMFoam - change in volume fraction gopala OpenFOAM Running, Solving & CFD 0 April 27, 2009 10:46
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
