internal flow BCs: pressure driven versus velocity driven
Like Tree5Likes
Old   September 7, 2012, 14:18
MBA
anonymous
MBA is on a distinguished road
Since you are using simpleFoam just add the following:
type totalPressure;
gamma 1.0;
p0 uniform 0;
value uniform 0;
You should be O.K now.
MBA is offline   Reply With Quote
Old   March 6, 2014, 10:00
Question BC Total Pressure
  #22
vut
vut is on a distinguished road
Dear OpenFoamers,
I would like to set up my study case: a water flow through a channel by simpleFoam.
I want to set boundary conditions as total pressure: (1 bar at inlet and 0 bar at outlet).
Now I have:
p
inlet
type fixedValue
uniform 100
? for simpleFoam pressure = pressure/mass density, right?
outlet
type fixedValue
uniform 0
U
inlet
type pressureInletVelocity
uniform (0 0 0)
outlet
type zeroGradient
It does not work when I ran simpleFoam! It stops after several iterations.
I really don't understand what happened.
Do you known why, rather why not?
I am looking to hear from you all...
Regards,
T
Originally Posted by Tobi View Post
Hi all,
for the totalPressure BC there are different ways for calculation. It depends on the initialization of the BC. But first to your question @lobstar.
gamma = Heat capacity ratio
That is the important code for totalPressure:
    if (psiName_ == "none" && rhoName_ == "none")
        operator==(p0p - 0.5*(1.0 - pos(phip))*magSqr(Up));
    else if (rhoName_ == "none")
        const fvPatchField<scalar>& psip =
            patch().lookupPatchField<volScalarField, scalar>(psiName_);
        if (gamma_ > 1.0)
            scalar gM1ByG = (gamma_ - 1.0)/gamma_;
            operator==
                p0p
               /pow
                    (1.0 + 0.5*psip*gM1ByG*(1.0 - pos(phip))*magSqr(Up)),
                    1.0/gM1ByG
        else
            operator==(p0p/(1.0 + 0.5*psip*(1.0 - pos(phip))*magSqr(Up)));
    else if (psiName_ == "none")
        const fvPatchField<scalar>& rho =
            patch().lookupPatchField<volScalarField, scalar>(rhoName_);
        operator==(p0p - 0.5*rho*(1.0 - pos(phip))*magSqr(Up));
depend on your BC initialization you calculate in different ways.
In the constructors you find the way how to set this bc correct and if you do not set an value which value would be set instead - an example that works:
outlet
        type               totalPressure;
        p0                  uniform 100000;
        psi                  none;
        gamma            0;
        rho                 rho;
        value              uniform 100000;
and that lead you to that calculation:
If you set rho=none and psi=none (like in incompressible flows) you get the same calculation without rho:
its here:
Hope it will help you.
Tobi
vut is offline   Reply With Quote
Old   March 6, 2014, 10:06
vut
Thank MBA for your answer.
That's for p, right? And for both inlet and outlet?
Preciously, I change in constant/transportProperties nu = 1e-6 to simulate water. It's OK?
May you give me more details... That's would be useful.
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 00:11
Channel flow: Inlet pressure AND uniform velocity? frmap1 Main CFD Forum 0 April 15, 2010 10:32
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet gabriel OpenFOAM Running, Solving & CFD 16 September 30, 2009 18:20
Urgent: How to model a stationary sphere in a pressure driven flow using Ansys CFX? farhan OpenFOAM Running, Solving & CFD 1 April 14, 2009 14:34
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
