Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
wallHeatFlux error
Old   November 23, 2014, 19:38
Default wallHeatFlux error
Raghav
raghav.venky is on a distinguished road
I'm trying to simulate a forced convection problem using the buoyantBoussinesqSimpleFoam solver.
When I run the wallHeatFlux utility, I get this error:
Create time
Create mesh for time = 0
Time = 0
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::compressible::mutkWallFunctionFvPatchScalarField::calcMut() const at ??:?
#4  Foam::compressible::mutWallFunctionFvPatchScalarField::updateCoeffs() at ??:?
#5  Foam::fvPatchField<double>::evaluate(Foam::UPstream::commsTypes) at ??:?
#6  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() at ??:?
#7  Foam::compressible::RASModels::kEpsilon::kEpsilon(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&, Foam::word const&) at ??:?
#8  Foam::compressible::RASModel::adddictionaryConstructorToTable<Foam::compressible::RASModels::kEpsilon>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:?
#9  Foam::compressible::RASModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:?
#10  Foam::compressible::turbulenceModel::addturbulenceModelConstructorToTable<Foam::compressible::RASModel>::NewturbulenceModel(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:?
#11  Foam::compressible::turbulenceModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:?
#12
 at ??:?
#13  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#14
 at ??:?
Floating point exception (core dumped)
the simulationType in the turbulenceProperties file is RASModel. If i change it to laminar, the utility works and calculates the fluxes on the walls. What could be the problem?
contents of the constant folder attached.
Thanks
File Type: gz constant.tar.gz (938 Bytes, 4 views)
raghav.venky is offline   Reply With Quote
Old   November 24, 2014, 06:27
Joachim Herb
jherb is on a distinguished road
I am confused: You use buoyantBoussinesqSimpleFoam but with compressible turbulence model/wall function? Have a look at the tutorials for this solver. If I remember correctly it only uses an expansion factor to calculate the density change by temperature but not a full thermophysical model.
jherb is offline   Reply With Quote
Old   December 22, 2014, 07:49
Muhammad Omer Mughal
Muhammad Omer Mughal is on a distinguished road
Dear Raghav
I am having same error. Can you please advise how you solved it. I shall be grateful.
Thanks
Muhammad Omer Mughal is offline   Reply With Quote
Old   December 31, 2018, 03:17
Bidesh Sengupta
BSengupta is on a distinguished road
Hi Can any one please help me to overcome it.. Thank you very much.
Overall domain bounding box (0 0 0) (1 0.4 0.1)
Error:
Time = 10
GAMG: Solving for Ux, Initial residual = 0.424802, Final residual = 0.017996, No Iterations 1
GAMG: Solving for Uy, Initial residual = 0.332272, Final residual = 0.0140346, No Iterations 1
GAMG: Solving for Uz, Initial residual = 0.559406, Final residual = 0.0285128, No Iterations 1
GAMG: Solving for e, Initial residual = 0.574963, Final residual = 0.0496275, No Iterations 1
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:?
#4 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:?
#5 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam"
Model: rhoSimpleFoam
Boundary Condition:
1. Pressure
frontandback
type symmetry;
inlet
type zeroGradient;
//type mixed;
//refValue uniform 100000;
//refGradient uniform 0;
//valueFraction uniform 0.3;
outlet
type fixedValue;
value uniform 100000;
wall
type zeroGradient;
2. Velocity
frontandback
type symmetry;
inlet
type fixedValue;
value uniform (5 0 0);
rhoInlet 1.5;
outlet
type zeroGradient;
wall
type noSlip;
3. Temperature
frontandback
type symmetry;
inlet
type fixedValue;
value uniform 300;
outlet
type zeroGradient;
wall
type zeroGradient;
4. k
frontandback
type symmetry;
inlet
type turbulentMixingLengthDissipationRateInlet;
mixingLength 0.14;
value uniform 0.1;
outlet
type inletOutlet;
inletValue uniform 1;
value uniform 1;
wall
type kqRWallFunction;
value uniform 1;
5. epsilon
frontandback
type symmetry;
inlet
mixingLength 0.14;
value uniform 0.006;
outlet
type inletOutlet;
inletValue uniform 0.006;
wall
type epsilonWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
6. nut
frontandback
type symmetry;
inlet
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
wall
type nutkWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0;
7. alphat
frontandback
type symmetry;
inlet
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
wall
type compressible::alphatWallFunction;
Prt 0.85;
value uniform 0;
fvSolution
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss upwind;
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
div(phi,e) bounded Gauss upwind;
div(phi,epsilon) bounded Gauss upwind;
div(phi,k) bounded Gauss upwind;
div(phid,p) Gauss upwind;
div(phi,Ekp) bounded Gauss upwind;
div((phi|interpolate(rho)),p) Gauss upwind;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fvSolution
solvers
p
solver GAMG;
tolerance 1e-08;
relTol 0.1;
smoother GaussSeidel;
nCellsInCoarsestLevel 20;
"(U|e|k|epsilon)"
solver GAMG;
tolerance 1e-08;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
rhoMin 0.1;
rhoMax 1.5;
//pMaxFactor 2;
//pMinFactor 0.1;
transonic yes;
consistent yes;
residualControl
p 1e-3;
U 1e-4;
e 1e-3;
// possibly check turbulence fields
"(k|epsilon|omega)" 1e-3;
relaxationFactors
fields
p 0.3;
rho 0.7;
equations
p 0.7;
U 0.7;
e 0.7;
k 0.7;
epsilon 0.7;
BSengupta is offline   Reply With Quote
rasmodel, turbulence, wallheatflux
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
