buoyantboussinesqsimplefoam solver for laminar flow |
July 10, 2011, 14:49 |
alireza golzari
Rep Power: 14 |
Hi Dear foamers
I'm a new user of openfoam and I'm trying to simulate a pipe through which a fluid passes in laminar flow and is being heated. for this problem I'm using buoyantboussinesqsimplefoam solver and my RASProperties file is as follows: FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object RASProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // RASModel laminar; turbulence off; printCoeffs on; ///////////////////////////////////////////////// but openfoam does not run my case and following errors appear: Create time Create mesh for time = 0 Reading g Reading thermophysical properties Reading field T Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Creating turbulence model Selecting RAS turbulence model laminar Calculating field beta*(g.h) Starting time loop Time = 1 LHS and RHS of - have different dimensions dimensions : [0 3 -2 0 0 0 0] - [1 0 -2 0 0 0 0] #0 Foam::error:rintStack(Foam::Ostream&) in "/home/alireza/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/alireza/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam:perator-(Foam::dimensionSet const&, Foam::dimensionSet const&) in "/home/alireza/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #3 Foam::tmp<Foam::GeometricField<Foam::typeOfSum<dou ble, double>::type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam:perator-<double, double, Foam::fvsPatchField, Foam::surfaceMesh>(Foam::tmp<Foam::GeometricField< double, Foam::fvsPatchField, Foam::surfaceMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/home/alireza/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/buoyantBoussinesqSimpleFoam" #4 main in "/home/alireza/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/buoyantBoussinesqSimpleFoam" #5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 From function operator-(const dimensionSet& ds1, const dimensionSet& ds2) in file dimensionSet/dimensionSet.C at line 423. FOAM aborting Aborted ///////////////////////////////////////////////////// unfortunately I don't understand the source of these errors. could anybody here help me to correct my case? Please give me your valuable advises, please! |
July 11, 2011, 04:39 |
Samuel ARNAUD
Rep Power: 15 |
Hi Alireza,
the error tells you that you have wrongly defined the boundary unit. if you compare: [0 3 -2 0 0 0 0] with [1 0 -2 0 0 0 0] m3.s-2 with kg.s-2 => therefore a difference in kg/m3 My guess is: I bet your p/p_rgh initial value are define with [1 -1 -2 0 0 0 0] Change it to: [0 2 -2 0 0 0 0] and you'll be fine. The reason: depending the solver, density can be included or not Best regards,
Sam |
July 12, 2011, 01:22 |
alireza golzari
Rep Power: 14 |
Dear samuel
Thanks a lot You are right I made the changes and my case run Thanks a milion for your help |
July 12, 2011, 02:57 |
Samuel ARNAUD
Rep Power: 15 |
you're most welcome
Sam |
May 2, 2012, 07:03 |
anonymous
Rep Power: 14 |
Hi!
I have a similar simulation, and when I run the problem, an error ocurrs: --> FOAM FATAL ERROR: Invalid wall function specification Patch type for patch top must be wall Current patch type is patch From function kappatJayatillekeWallFunctionFvPatchScalarField::c heckType() in file derivedFvPatchFields/wallFunctions/kappatWallFunctions/kappatJayatillekeWallFunction/kappatJayatillekeWallFunctionFvPatchScalarField.C at line 56. FOAM aborting I change the geometry and everythings it's ok, but the error says that the surface "top" it's not a wall, and I don't know what I have to do, some ideas?? |
May 2, 2012, 08:06 |
#6 | |
Nima Samkhaniani
Rep Power: 24 |
look at constant/polyMesh P.S. if you read the error carefully, the solution is in it !!! |
May 3, 2012, 03:22 |
#7 | |
anonymous
Rep Power: 14 |
Another question, If I run my simulation and then I change some parameters and I run it again, paraFoam gives me the same results as the first run. How can I restart the simulation to obtain the new results? thanks!! (I change the writeInterval, but in my directory appears the same folders as before). |
Solver for an incompressible, turbulent flow with heat transfer | tH3f0rC3 | OpenFOAM Running, Solving & CFD | 9 | June 17, 2019 06:12 |
How do I select solver options for external flow over an aircraft by fluent? | hadieliasi | FLUENT | 5 | May 2, 2011 03:54 |
pre-conditioning for low mach number compressible flow solver | Shenren_CN | Main CFD Forum | 0 | April 29, 2011 21:07 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
