Mesh conversion
Old   April 10, 2012, 15:59
Default Mesh conversion
MultiphaseFlowsLab is on a distinguished road
I tried to convert .msh file to openfoam mesh file. and I used fluentMeshToFoam command but I faced an error.
Could someone help me in mesh conversion? I'm new in OpenFoam and have several problems in running my case.
MultiphaseFlowsLab is offline   Reply With Quote
Old   April 10, 2012, 16:10
Hannes
falke126 is on a distinguished road
Could you post the error message?
Then itīs easier to give hints, what the problem is...
falke126 is offline   Reply With Quote
Old   April 10, 2012, 16:23
Thanks for your reply.
my error is:
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/maryam/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Old   April 11, 2012, 06:30
flowris is on a distinguished road
You have to go into your case folder and then execute your mesh conversion command. Make sure there is also a system folder, containing a controlDict.
flowris is offline   Reply With Quote
Old   April 11, 2012, 14:01
Thanks for your help. I did it and when I try to convert fluent mesh file to OF following results are shown .
My geometry is complex and 3D.
Found end of section in unknown:�
� �Embedded blocks in comment or unknown:�
�Embedded blocks in comment or unknown:]
� ݙFound end of section in unknown:�
Embedded blocks in comment or unknown:`
Embedded blocks in comment or unknown:��
� [Embedded blocks in comment or unknown:`
��{ 'Embedded blocks in comment or unknown:��
��-w?Embedded blocks in comment or unknown:U�
Found end of section in unknown:?
�� Found end of section in unknown:�
�|Embedded blocks in comment or unknown:}�
�Found end of section in unknown:?
j?h Aq?t;M ��8
Old   April 12, 2012, 04:30
Default Mesh convertion
ahmed
ahmed_khatibs is on a distinguished road
make sure that ascii or binary (u have given in controlDict file ) or use only ascii formate.
  • Save .msh in ascii formate.
  • use fluentMeshToFoam for convert.
thank u
ahmed_khatibs is offline   Reply With Quote
Old   April 12, 2012, 08:37
Hannes
E.g. in Ansys Meshing you have to change an environment variable to get the Fluent Mesh files saved in ascii format. By default, they are saved in binary format.
Old   April 18, 2012, 12:35
Thanks everybody. Finally it works.
Old   April 27, 2012, 13:28
Default Boiling model
I need to simulate boiling flow, I went through cavity tutorial. But I am very new to OF and I don't know how can I use its applications and utilities. I really appreciate if someone can tell me step by step creating my own case.
(I really have time limit so it takes too much time to find it from several articles)
Old   April 28, 2012, 11:07
Hannes
The best way is to look for a tutorial case, that is similar to your problem.
You can modify the existing case, so that it fits to your problem.
Can you give a short describtion of the case that you want to simulate?
Old   May 1, 2012, 12:08
My case is a annuli which has heater inside, so I need to have constant Q B.C. and I have single phase flow inlet but at the end it becomes two phase. I need to track bubbles behavior.
Old   May 1, 2012, 14:14
Hannes
2-phase flow (VOF-Model) with a one phase Q-Inlet should be no problem (e.g. interFoam).
But I donīt know, if a boiling model exists in OpenFoam...
Old   May 2, 2012, 12:43
Thanks ,You mean that I can use interFoam /damBreak and I should add boiling model to it?!
Old   May 2, 2012, 12:52
And I have no idea what is the usage of Utilities in OF?
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Commercial meshers] Icem cfd multidomain mesh conversion Attesz OpenFOAM Meshing & Mesh Conversion 2 May 2, 2013 11:03
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
