[blockMesh] Problem with blockMesh boundaries
Old   May 8, 2012, 04:29
Default Problem with blockMesh boundaries
Elise
Elise is on a distinguished road
When I try to make a mesh with blockMesh; the vertices are ok.
But I can not do a refinement I like; I get the error inconsistent point locations between block pair 0 and 2.
When I put in the old settings for the refinement and try to make the boundaries, everytime I get the error that there are no neighbour cells or patches for certain patches.
I put in the picture and blockMesh file.
Elise is offline   Reply With Quote
Old   May 8, 2012, 04:51
akidess's Avatar
Anton Kidess
Depending on your vertex ordering each block gets a local coordinate system (see figure 5.5). I'm guessing if you draw the local coordinate systems in your case, you will have anti-parallel vectors in some directions.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   May 8, 2012, 05:56
Elise
Ok. I looked at the consistancy of all the directions and local coordinates.
I also learned that for the different regions at the top, I had to make different regions at the bottom as well, instead of 1 bottom patch.
Now it works, I attached the file
[blockMesh] blockMesh with parametric mesh. Unusual and unseen problem 13msmemusman OpenFOAM Meshing & Mesh Conversion 1 June 13, 2016 02:25
problem running blockMesh in ubuntu terminal (openfoam) subhsngh OpenFOAM Running, Solving & CFD 6 June 26, 2013 08:02
[blockMesh] Problem with blockMesh and my shape TneurolF OpenFOAM Meshing & Mesh Conversion 4 June 25, 2013 13:52
Blockmesh problem with more than one block sven82 OpenFOAM Pre-Processing 1 June 4, 2013 17:08
2D simpleFoam simulation gets stuck - no error - problem with boundaries? lovecraft22 OpenFOAM 10 July 15, 2011 13:51
