Laminar flux
Old   May 7, 2012, 03:55
Default Laminar flux
anonymous
libia87 is on a distinguished road
HI!
I want to simulate a laminar flux in the tutorial "buoyantboussinesqsimplefoam". I change the RASProperties:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object RASProperties;
RASModel laminar;
turbulence off;
printCoeffs on;
My question is if it's sufficient to do this to simulate a laminar flux,
thanks!!!
libia87 is offline   Reply With Quote
Old   May 7, 2012, 06:59
niaz's Avatar
A_R
niaz is on a distinguished road
you should change turbulenceProperties to laminar
niaz is offline   Reply With Quote
Old   May 8, 2012, 03:10
anonymous
in this tutorial there isn't turbulenceProperties, in /constant there are "g", "RASProperties" and "transportProperties"
Old   May 8, 2012, 04:17
niaz's Avatar
A_R
Dear libia
ye that is enough. You can check that your solver will not solve k and epsilon equations and your nut file has constant value. And you can delete them from your 0/ directory.
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 07:08
Laminar flux libia87 OpenFOAM 4 September 5, 2012 13:51
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 09:50
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
