cell volume calculation
Old   September 15, 2011, 09:54
Default cell volume calculation
Mike
mikemech is on a distinguished road
I'm facing this problem:
I want to calculate the volume of a certain cell that is contained in my grid.
Is there any straightforward method for doing that?
Thank you.
mikemech is offline   Reply With Quote
Old   September 15, 2011, 10:20
romant's Avatar
Roman Thiele
romant is on a distinguished road
you could create a field for all the cell volumes and then access your specific cell the field is created with
    volScalarField cellVolu
    IOobject
        "cellVolu",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::AUTO_WRITE
        mesh,
    dimensionedScalar("zero", dimVolume, 0.0)
    cellVolu.internalField() = mesh.V();
and access to the volume of a specific cell is then given by
cellVolu()[cellIndex];
or right away by
mesh.V()[cellIndex]
have a look at similar things
http://www.cfd-online.com/Forums/ope...ne-volume.html
~roman
romant is offline   Reply With Quote
Old   September 15, 2011, 10:31
Mike
Hi romant,
You mean that if I type in the terminal window "mesh.V()[34332]" I ll get the volume of cell number 34332 ?
Old   September 15, 2011, 10:43
romant's Avatar
Roman Thiele
no this should have been in C++ in the source code.
~roman
Old   September 16, 2011, 04:06
Tomislav Maric
tomislav_maric is on a distinguished road
Thank you.
There is a Foam::cell::mag() method for this. It is local and approximative:
cell.C:
00238 Foam::scalar Foam::cell::mag
00239 (
00240     const pointField& p,
00241     const faceUList& f
00242 ) const
00243 {
00244     // When one wants to access the cell centre and magnitude, the
00245     // functionality on the mesh level should be used in preference to the
00246     // functions provided here. They do not rely to the functionality
00247     // implemented here, provide additional checking and are more efficient.
00248     // The cell::centre and cell::mag functions may be removed in the future.
00249
00250     // WARNING! See cell::centre
There are more accurate ways of computing cell magnitude (polyhedron volume)
than this one, and you should check out the literature if you absolutely need local computations. Do you need the volume of a single cell (set of cells), or do you need mesh level operations?
If you just want a volume of a single cell, or a zone of cells defined by some
criterion, you can go about it like this:
const cellList& cells = mesh.cells();
const faceList& faces = mesh.faces();
const pointField& points = mesh.points();
// Let's say that you want a volume of the 100th cell..
scalar cellV = cells[100].mag(points,faces);
Of course, finding out the proper label for the cell(s) will depend on what you
actually want to do.
T.
tomislav_maric is offline   Reply With Quote
Old   September 16, 2011, 06:58
Mike
Thank you tomislav_maric,
Well I need to find the volume of one cell, and I know its label.
So I ll try the second idea you mentioned.
Old   September 17, 2011, 07:38
Tomislav Maric
Cool, I'm glad to be of help!
T.
Old   October 11, 2011, 09:43
alex
oort is on a distinguished road
Hi!
If i put
cellVolu.write();
bellow the "cellVolu.internalField() = mesh.V();" is written the cellVolu field.
How can I sum all the cell volumes? I want calculate the global volume of my geometry.
Thanks.
    IOobject
        "cellVolu",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        mesh,
or right away by
mesh.V()[cellIndex]
oort is offline   Reply With Quote
Old   October 11, 2011, 10:03
Default global volume
romant's Avatar
Roman Thiele
Hej,
it is easiest calculated
scalar volumeSum = sum(cellVolu).value();
or if you don't need it in a program, just run
checkMesh
which will give you the total volume as one of the outputs.
~roman
Old   October 11, 2011, 10:48
alex
Thanks romant.
The total cell's volume given by your method have deviation from "geometric" calculations of 0.002% in my mesh.
Old   May 23, 2012, 17:15
pvpnr is on a distinguished road
Originally Posted by oort View Post
Hi!
If i put
cellVolu.write();
Thanks.
in which source code file do we have to make these changes
pvpnr is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
gradient calculation of cell centered finite volume method zhengjg Main CFD Forum 10 November 11, 2012 23:13
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Calculation of cell volume and face handedness Mark FLUENT 0 August 30, 2001 07:45
