about fvSolution settings for interPhaseChangeFoam
Old   July 11, 2011, 19:54
Default about fvSolution settings for interPhaseChangeFoam
Chih-Che Chueh
chueh is on a distinguished road
I am facing an error when using interPhaseChangeFoam. The error message is presented as follows:
--> FOAM FATAL IO ERROR:
keyword maxIter is undefined in dictionary "/gwork/chueh/FOAM/release/VOF_XTC/staticContactAngle/test_temp/system/fvSolution::solvers::alpha1"
file: /gwork/chueh/FOAM/release/VOF_XTC/staticContactAngle/test_temp/system/fvSolution::solvers::alpha1 from line 56 to line 65.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 395.
FOAM exiting
But I don't figure out why the error still comes out because I have already added the alpha1's declaration into the "fvSolution" file as follows:
alpha1
MULESImplicit
maxIter 1000;
nLimiterIter 10;
maxUnboundedness 1;
CoCoeff 0.2;
solver
solver PBiCG;
preconditioner DILU;
tolerance 1e-10;
relTol 0;
Does anyone know what went wrong with my fvSolution settings and help me out? Thanks!
Sincerely,
Chih-Che
chueh is offline   Reply With Quote
Old   July 13, 2011, 04:20
akidess's Avatar
Anton Kidess
You specified maxIter in a subdictionary ("MULESImplicit"), but your solver is expecting the keywords in the alpha1 dictionary. Get rid of MULESImplicit and put all keywords in the alpha1 dictionary, and all should be well.
-Anton
Old   July 13, 2011, 10:24
Chih-Che Chueh
Hi Anton, Thanks for your reply. The problem that I was facing is now resolved. Chih-Che
Old   March 1, 2012, 19:31
Default Singhal models
vahid
vahid.najafi is an unknown quantity at this point
My purpose is adding Zwart and Singhal models to interPhaseChangeFoam solver.
I transform Saur model to Zwart model successfully but transforming Saur model to Singhal model is faild!!!
my error is :
phaseChangeTwoPhaseMixtures/phaseChangeTwoPhaseMixture/phaseChangeTwoPhaseMixture.C:48: error: no matching function for call to ‘Foam::dimensioned<double>::dimensioned()’
Can you help me???
vahid.najafi is offline   Reply With Quote
Old   June 6, 2012, 09:49
Default adding k_:
vahid
I want to add the kinetic energy Turbulence(k) in model <<sauer>> in solver <<interPhaseChangeFoam>>.
I added the following line in the<<options>>:
-I$(LIB_SRC)/turbulenceModels/incompressible/RAS/RASModel \
Then with enter the <<k_>>in model <<sauer>>as following :
// * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * * //
Foam::tmp<Foam::volScalarField>
Foam: PhaseChangeTwoPhaseMixtures::SchnerrSauer::rRb
const volScalarField& limitedAlpha1
) const
return pow
((*4*constant::mathematical: pi*n_)/3)*k_
*limitedAlpha1/(1.0 + alphaNuc() - limitedAlpha1),
1.0/3.0
when I Type wmake in terminal.
I seen this message :
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:79: error: ‘k_’ was not declared in this scope
make: *** [Make/linux64GccDPOpt/SchnerrSauer.o] Error 1
please help me…
BC settings to expand pressure on atmosphere - simpleFoam / totalPressure sErik OpenFOAM Running, Solving & CFD 1 June 15, 2011 02:49
Best settings for solar car external flow problems kdrbrk Main CFD Forum 0 July 16, 2010 02:18
General help for fvSchemes and fvSolution settings harly OpenFOAM Running, Solving & CFD 4 September 7, 2009 10:31
Default settings for 3D boundary layer-Gambit 2.2 Ramine FLUENT 1 July 31, 2006 12:36
help on memory settings in TASCflow Dr C.Bhasker CFX 1 September 5, 2001 05:57
