[swak4Foam] SWAK4FOAM_SRC environment variable
Like Tree1Likes
  • 1 Post By gschaider
Old   June 15, 2012, 09:14
Default SWAK4FOAM_SRC environment variable
Felipe
fcuevas is on a distinguished road
Hi everybody,
I'm trying to run the CodeStream/cylinderWithSwak example included in swak4Foam library but I have this error
Create time
Create mesh for time = 0
Reading field p
Reading field U
Calculating potential flow
swak4Foam: Allocating new repository for sampledGlobalVariables
--> FOAM FATAL ERROR:
Compilation of the function object only works if the environment variable SWAK4FOAM_SRC points to the Libraries directory of the swak4Foam-sources
From function swakCodedFunctionObject::read(const dictionary& dict)
in file swakCodedFunctionObject.C at line 225.
FOAM exiting
In the README file says for the swakFunctionObjects library: "... Assumes that the =SWAK4FOAM_SRC= environment variable is set to the Libraries=-directory of the =swak4Foam=-sources"
but I don't really know where/when can I set the environment variable (before I compile all swak4Foam or in the controlDictof the case that use this library or...)
The swak4Foam library is installed in $(WM_PROJECT_USER_DIR)/lib/swak4Foam and the compilation doesn't show any strange problem (as far as I know), actually I can use without problems the groovyBC library.
How and where should I set the environment variable?
Regards,
Felipe
fcuevas is offline   Reply With Quote
Old   June 15, 2012, 14:55
Assistant Moderator
Bernhard Gschaider
Originally Posted by fcuevas View Post
Hi everybody,
Create time
Reading field p
Reading field U
FOAM exiting
Regards,
Felipe
The thing is that the functionObject has to know where to find the swak4Foam-sources. As this is not standard-OF-software it depends on the user where it is installed and I didn't want to force anyone on a specific location (because usually 20% are not allowed to install it there because of administrative policies anyway ...) so the user has to give an indication by setting that environment variable. Setting an environment variable depends on the shell you're using. For the location you're giving and the shell I usually use (bash or zsh) you'd type
export SWAK4FOAM_SRC=$WM_PROJECT_USER_DIR/lib/swak4Foam/Libraries
for csh/tcsh it is setenv I think.
This variable is currently only needed for this functionObject as it is compiling something that requires the swak-headers. groovyBC and friends only need binaries (which you compiled at the start) and don't care where the sources are.
I'll add a test to the Allwmake that prints the proposed value for SWAK4FOAM_SRC
Where you actually set the environment variable (bashrc in your home, the site-configuration of OF, ...) is up to you
nvnkush likes this.
Old   June 18, 2012, 09:58
Felipe
Set on bashrc, works perfectly
Regards,
Felipe
Environment variable in CCM+ crevoise STAR-CCM+ 0 November 12, 2013 04:29
Environment variable ($MPI_PROCS) in decomposeParDict Pj. OpenFOAM Running, Solving & CFD 2 April 8, 2013 02:38
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
