setFields tool does not assign water volume for given mesh. |
April 2, 2011, 20:28 |
Rep Power: 18 |
Good day to everyone!
I already described my problem in different threat, however, since it is not particularly related to Gmsh, but to setFields tool I post the link to the other thread: http://www.cfd-online.com/Forums/ope...-possible.html I hope someone can help me. setFields tool is not assigning the water volume for a given mesh produced with Gmsh. checkMesh does not generate any errors. I'm able to use flattenMesh and refineMesh. No errors are produced, all seems to be fine. However while trying to assign a volume of fluid using setFields command for interFoam solver, the domain is not assigned. Thanks, K |
June 7, 2012, 03:02 |
chenjinnan
hey ,paka
the format of boxToCell should be box(x_min y_min z_min) (x_max y_max z_max) the same question can be found in http://www.cfd-online.com/Forums/ope...ge-fields.html jeff best regards |
June 7, 2012, 09:17 |
Rep Power: 18 |
Many thanks for the follow up. I'm sure it will hep someone else in the future.
Regards, K |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
mesh missing after export in gambit | morteza08 | ANSYS Meshing & Geometry | 1 | July 26, 2010 01:10 |
Volume mesh for Fluent.. Hypermesh or TGrid?? | mayur | FLUENT | 5 | June 25, 2010 01:45 |
[GAMBIT] Placing Specific Mesh Nodes in a Volume Mesh | davisi | ANSYS Meshing & Geometry | 0 | November 12, 2009 07:44 |
