continuity Error when using mapFields
Old   July 24, 2012, 05:53
Default continuity Error when using mapFields
Samuele Z
samiam1000 is on a distinguished road
Dear all,
I am trying to use the mapField command.
Indeed, it works pretty well.
The point is that I get an error when I try to launch the buoyantSimpleFoam command.
The error is the following:
rduser@slnxepmi05:/OPENFOAM/cases/moving_door_def_flow/0DegStartSimple$ buoyantSimpleFoam
|  \\    /   O peration     | Version:  2.1.0                                 |
Build  : 2.1.0-0bc225064152
Exec   : buoyantSimpleFoam
Date   : Jul 24 2012
Time   : 11:40:20
Host   : "slnxepmi05"
PID    : 24038
Case   : /OPENFOAM/cases/moving_door_def_flow/0DegStartSimple
nProcs : 1
Create time
Create mesh for time = 0
Reading g
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
    Prt             1;
Calculating field g.h
Reading field p_rgh
SIMPLE: convergence criteria
    field p_rgh	 tolerance 0.01
    field U	 tolerance 0.001
    field h	 tolerance 0.001
    field "(k|epsilon|omega)"	 tolerance 0.001
Starting time loop
Time = 1
DILUPBiCG:  Solving for Ux, Initial residual = 0.75027308, Final residual = 0.0059180187, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.97031907, Final residual = 0.0078913271, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.82258021, Final residual = 0.0061307245, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.00024857446, Final residual = 2.2807101e-06, No Iterations 1
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux              : 1226.2338
Specified mass inflow   : 1.074375
Specified mass outflow  : 1.0743555
Adjustable mass outflow : 0
    From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p
    in file cfdTools/general/adjustPhi/adjustPhi.C at line 118.
FOAM exiting
Can anyone help?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   November 20, 2017, 14:40
Bhanu
mugabe2204 is on a distinguished road
Hi Samuele,
Were you able to resolve this ? I have the same issue.
Especially I want to convert the fixed Value ( zero) pressure outlet to fixed flux pressure or zerogradient and I have the simulation being run. When I tried to map to the test cases with new boundary conditions, it gives the same error.
Thanks in advance.
Cheers
mugabe2204 is offline   Reply With Quote
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
