Setting Mass source in interFoam
Old   June 11, 2018, 22:01
Default Setting Mass source in interFoam
AhmadZ is on a distinguished road
Hello all,
I am using interFoam to simulate falling liquid droplets onto a solid surface.
I am wondering if there is a possibility to add a mass source at some times, in the form of injected spherical liquid droplets, with specific diameter and velocity at a specific location.
I have tried with the attached fvOptions. It worked for the momentum but not for alpha. I am using of5 and of1712.
I got the following warning while running the case
From function virtual void Foam::fvption::checkApplied() const
in file cfdTools/general/fvOptions/fvOption.C at line 125
Source scalarSource defined for field alpha1 but never used
Any hint is highly appreciated.
File Type: gz fvOptions.gz (537 Bytes, 31 views)
AhmadZ is offline   Reply With Quote
Old   October 24, 2018, 09:14
Ashish Vinayak
ashish.vinayak is on a distinguished road
fvOptions if not defined in the alpha equation. Hence you are unable to use it.
ashish.vinayak is offline   Reply With Quote
Old   May 28, 2019, 12:38
Cool define fvOptions in interFoam
Ludo Masci
lumasci is on a distinguished road
OK, then can you tell how to define fvOptions in the alpha equation?
lumasci is offline   Reply With Quote
Old   May 28, 2019, 13:03
Ashish Vinayak
Hi Lumasci,
Well, you can't. fvOptions has not been initialized at all in the alphaEquation.
This means that, even if you define a fvOptionsDict for volScalarField alpha, it will not work.
You have two options in my opinion (I might be wrong, since my knowledge about this kind of source term is rather limited) -
1. Program a source term into the solver for the alpha equation
or
2. Add the source term to the MULES solver.
Note: I don't think either of these will be trivial tbh.
Old   May 29, 2019, 03:02
Ludo Masci
Thanks for the reply. I am indeed trying to program a source term into the solver. Not an easy task.
fvoptions, injection, interfoam, mass source
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
Mass source, Momentum source theory. diffo FLUENT 4 August 21, 2009 10:26
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 06:10
