how to write temperature to a file
Like Tree2Likes
  • 1 Post By niaz
  • 1 Post By niaz
Old   July 26, 2012, 08:47
Default how to write temperature to a file
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am running buoyantSimpleFoam and I would like to save the temperature of a patch (my_outlet) in a text file.
What I would like to do is to save either the sum ot the temperature of each cell (that belongs to the patch) or writing the temperature of the cells in a line.
In the first case I'll have a file with 1 column and n lines (with n = number of iterations), while in the second case I'll have a m x n file (where m = number of cell belonging to the patch).
How can I do this?
Any idea?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   July 26, 2012, 16:12
niaz's Avatar
A_R
niaz is on a distinguished road
you should use face object
just add these lines to control dict
functions
faceObj1
type faceSource;
functionObjectLibs ("libfieldFunctionObjects.so");
enabled true;
outputControl outputTime;
// Output to log&file (true) or to file only
log true;
// Output field values as well
valueOutput true;
// Type of source: patch/faceZone/sampledSurface
source patch;
// if patch or faceZone: name of patch or faceZone
sourceName movingWall;
//// if sampledSurface: dictionary with a sampledSurface
//// Note: will not sample surface fields.
//sampledSurfaceDict
// // Sampling on triSurface
// type sampledTriSurfaceMesh;
// surface integrationPlane.stl;
// source cells; // sample cells or boundaryFaces
// interpolate true;
// Operation: areaAverage/sum/weightedAverage ...
operation areaAverage;
fields
p
phi // surface fields not supported for sampledSurface
U
this will write your patch value for each time steps solved
samiam1000 likes this.
niaz is offline   Reply With Quote
Old   July 27, 2012, 06:35
Samuele Z
Dear Niaz,
thanks a lot for answering.
It really helped.
Just a question: do you know where I can find a list of available functions (probes, faceObj1..)?
Thanks a lot,
Samuele
Old   July 27, 2012, 09:38
niaz's Avatar
A_R
Dear sam
there are two functions which is helpful
1- src/sampling
2- src/postproceesing/functionobjects
in each folder you can find a controldict that show you how to use it
Old   July 31, 2012, 10:40
turbulencious is on a distinguished road
hey guys,
this seems to be quite useful for me. Could you please make it a bit more clear, how exactly we set the commands for writing the Temperature in a file, as a function of time?
I tried to use the commands posted above but without success
thanks in advance
turbulencious is offline   Reply With Quote
Old   July 31, 2012, 10:42
Samuele Z
Just paste this code
functions
faceObj1
type faceSource;
enabled true;
log true;
valueOutput true;
source patch;
fields
T
in your system/controlDict.
Then you'll have a file with the temperature!
Does this help?
Old   July 31, 2012, 11:05
hey Samuele, thanks a lot for your immediate response!
well, I pasted what you wrote but unfortunately it doesnt work. The only thing I have changed is the sourceName movingWall; and I entered the name of my outlet.
I get this message:
--> FOAM FATAL ERROR:
request for objectRegistry region0 from objectRegistry aplo1 failed
available objects of type objectRegistry are
3
fluid
pla1
pla2
From function objectRegistry::lookupObject<Type>(const word&) const
in file db/objectRegistry/objectRegistryTemplates.C at line 131.
where fluid, pla1, pla2 are the regions in my problem. (pla1 & pla2 are solid)
I would be really grateful if you help me through this.
cordially,
giorgos
Old   July 31, 2012, 11:29
Samuele Z
Is your outlet defined as a patch?
Could you copy your constant/polyMesh/boundary?
Thanks,
Samuele
Old   July 31, 2012, 11:39
hey Samuele,
thanks again for your consideration!
So, yes my outlet is defined as patch (it seems to work ok - the fluid is actually going out).
here is the constant/polyMesh/boundary
my outlet at this point is bottom (sometimes will be also the top)
akres-ar and akres_de are the solid walls outside of the domain
5
    akres_ar
        type            wall;
        nFaces          80;
        startFace       10096;
    akres_de
        type            wall;
        nFaces          192;
        startFace       10176;
    bottom
        type            patch;
        nFaces          8;
        startFace       10368;
    top
        type            patch;
        nFaces          8;
        startFace       10376;
    frontBack
        type            empty;
        nFaces          10240;
        startFace       10384;
Old   August 1, 2012, 02:49
Samuele Z
I try to write the system/controlDict for you.
You should add these lines, at the end:
functions
faceObj1
type faceSource;
enabled true;
log true;
valueOutput true;
source patch;
sourceName bottom;
fields
T
Which version of OF are you running?
Old   August 1, 2012, 03:49
hey Samuele,
thanks again. Unfortunately, this didnt work also. It gives me the same message that I have posted earlier.
available objects of type objectRegistry are.......
I am using the latest version, OF-2.1.1
If you find an idea to solve this I will be really grateful...
ciao
Old   August 1, 2012, 03:50
Samuele Z
Could you share your case with me?
I could test it and give it the solution (if I can find it!)..
Samuele
email: samuele.zampini@gmail.com
Old   August 1, 2012, 05:14
I sent it! very nice of you!
Old   May 30, 2019, 06:52
Default Update for OFv6
  #14
Deep
deepbandivadekar is on a distinguished road
This is a very old thread. But maybe this will help someone else save a few minutes. For OF v6 following works very well.
Add this to controlDict:
functions
    outletData
        type            surfaceFieldValue;
        libs            ("libfieldFunctionObjects.so");
        writeControl    timeStep;
        writeInterval   1;
        log             yes;
        writeTotalArea  no;
        writeFields     no;
        regionType      patch; //faceZone;
        name            outlet;
        fields
            p T U
deepbandivadekar is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
