weird looking yPlus graph
Old   August 14, 2012, 08:54
Default weird looking yPlus graph
Robert Ong
rob3rt 0ng is on a distinguished road
Hi All,
I run a k-omega SST incompressible flow past a hemisphere (generated from setSet utility). I normally get the y+ values from the display screen, and a bit puzzled when see this graph. Could you suggest whether this make sense?
Here's my checkMesh results:
PHP Code:
Mesh stats
    points
:           1084753
    faces
:            2854735
    internal faces
:   2821055
    cells
:            885214
    boundary patches
5
    point zones
:      0
    face zones
:       0
    cell zones
:       2
Overall number of cells of each type
hexahedra:     776644
    prisms
:        0
    wedges
:        0
    pyramids
:      0
    tet wedges
:    0
    tetrahedra
:    0
    polyhedra
:     108570
Checking topology
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Topological cell zip-up check OK.
Face vertices OK.
Face-face connectivity OK.
Number of regions(OK).
Checking patch topology for multiply connected surfaces ...
Patch               Faces    Points   Surface topology
    openwater           12800    13122    ok
(non-closed singly connected)
seafloor            6480     7031     ok (non-closed singly connected)
watersurface        4800     4941     ok (non-closed singly connected)
inlet               4800     4941     ok (non-closed singly connected)
outlet              4800     4941     ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-0.2 -0.0249 -0.2) (0.2 0.1 0.25)
Mesh (non-empty, non-wedgedirections (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-3.58035e-17 3.94272e-15 -6.20997e-17OK.
Max cell openness 3.11701e-16 OK.
Max aspect ratio 22.2347 OK.
Minumum face area 2.63529e-08Maximum face area 3.75002e-05.  Face area magnitudes OK.
Min volume 2.19607e-11Max volume 1.68703e-07.  Total volume 0.022482.  Cell volumes OK.
Mesh non-orthogonality Max84.1114 average9.80152
*Number of severely non-orthogonal faces7060.
    Non
-orthogonality check OK.
Writing 7060 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK
Max skewness 0.341033 OK.
Mesh OK.
End
Regards,
Robert
rob3rt 0ng is offline   Reply With Quote
How to calculate Y+( Yplus) mohammad Main CFD Forum 3 January 11, 2011 23:23
which yplus (SST) sanchezz CFX 17 January 11, 2010 04:45
How to plot different model's graph on a graph? echo Siemens 1 April 28, 2006 03:54
X-Y plot of Yplus in Fluent 5.3 Luo FLUENT 24 April 11, 2000 06:07
heat transfer coefficients with "bad" yplus Andrew Main CFD Forum 4 April 8, 1999 04:43
