Cyclic boundaries in OF 21x
Like Tree10Likes
Old   October 29, 2012, 10:53
Default Cyclic boundaries in OF 21x
Dejan Morar
morard is on a distinguished road
Hello to all,
first of all I want to apologize for opening a new thread although there is at least one with the similar name
http://www.cfd-online.com/Forums/ope...h-problem.html
but since I didn't find any answer I decided to post some questions here.
So, very briefly, I have a mesh which was ok in OF 1.7.1 but when I try to use it in 2.1.x version I've faced some errors with cyclic patches:
**Error in coupled point location: 300 faces have their 0th vertex not opposite their coupled equivalent. Average mismatch 0.0268041.
I was thinking that the problem might be in mesh numbering, so I try to re-number it but until now haven't found any solution.
Then I tried to investigate the mixer tutorial: incompressible/SRFSimpleFoam/mixer where the cyclic patches look like the patches in my case. I executed blockMesh and everything was fine. Then I tried to create just two blocks:
blocks
// hex (1 0 9 4 13 12 21 16) (10 20 40) simpleGrading (1 1 1)
hex (2 1 4 6 14 13 16 18) (2 20 40) simpleGrading (1 1 1)
hex (3 2 6 8 15 14 18 20) (10 20 40) simpleGrading (1 1 1)
// hex (5 10 0 1 17 22 12 13) (10 20 40) simpleGrading (1 1 1)
// hex (11 7 2 3 23 19 14 15) (10 20 40) simpleGrading (1 1 1)
with the following cyclic patch:
cyclic_half0
type cyclic;
neighbourPatch cyclic_half1;
transform rotational;
rotationAxis (0 0 1);
rotationCentre (0 0 0);
faces
//(0 9 21 12)
//(10 0 12 22)
(1 4 16 13)
cyclic_half1
type cyclic;
neighbourPatch cyclic_half0;
faces
//(3 15 20 8)
//(11 23 15 3)
(3 8 20 15)
and then I got the following error:
--> FOAM FATAL ERROR:
face 0 area does not match neighbour by 0.0664441% -- possible face ordering problem.
patch:cyclic_half0 my area:0.999336 neighbour area:1 matching tolerance:0.0001
Mesh face:1 fc0.553 0.507 1)
Neighbour fc0 0.75 1)
If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file.
Rerun with cyclic debug flag set for more information.
which is solved by adjusting the matchTolerance. But still, why does this error appear? The geometry is pretty simple, it should work without setting matchTolerance.
I'll also attach a blockMeshDict of the simple test case where the error mentioned at the top of the thread can be reproduced.
I think that there might be some convection about the block numbering in order to create good cyclics?
Does anybody have some comments, suggestions, ideas about this issue?
Regards,
Dejan
morard is offline   Reply With Quote
Old   October 30, 2012, 05:05
Dejan Morar
Hi again,
I've realised that the error appears only if the center of the patch rotational axis is not placed in the center of the coordinate system (0 0 0).
So, if I create a geometry in such a way that the center of the rotational axis is in the center of the coordinate system (0 0 0) the mesh is created without any problem.
But, If I now use the same mesh and shift it in x direction so that the rotational axis center is in (50 0 0), the error will appear! Why, I don't know!
Maybe it's a bug, but maybe not!
Regards,
Dejan
Old   November 14, 2012, 05:04
maddalena's Avatar
maddalena
maddalena will become famous soon enough
Hello Dejan,
I am experiencing the same "Error in coupled point location" running OF 2.1.0. Have you seen this: http://www.openfoam.org/mantisbt/view.php?id=403 ?
I think this may be helpful for you as well.
Please report if you have any news on the subject
mad
maddalena is offline   Reply With Quote
Old   November 14, 2012, 07:17
Dejan Morar
Hi Maddalena
thanks for your message. Yes, I saw that.
Well, that error depends somehow on the number of cells. When I put, for example, (20 15 50) cells for a certain block, everything is ok, but when I change it to, let say ( 30 20 50) - error! But this is just a small issue.
The big problem in my case is the following one:
More than one patch accessing the same transform but not of the same sign.
patch:fluid2_half0 transform:0 sign:1 current transforms1 0 0)
From function Foam::label Foam::globalIndexAndTransform::addToTransformIndex
const label,
const label,
const bool
) const
in file lnInclude/globalIndexAndTransformI.H at line 240.
FOAM exiting
This I cannot understand and I don't have time to check all those functions just for one geometry... If you understand what is wrong here, please let me know.
Dejan
Old   November 15, 2012, 09:45
maddalena's Avatar
maddalena
Hi Dejan,
I think the problem is related to point order on faces. The second error you are getting follows from the first. I doubt that renumbering mesh helps at all.
I solved my problems using OF 2.1.1 and using the createPatch utility on original (not defined cyclic) patches. As for your case: try to change blockmesh cell number on the original mesh and then run createPatch.
Hope this helps.
mad
Chandsome likes this.
Old   November 15, 2012, 11:50
Dejan Morar
Hi Maddalena,
yes, point order might be the problem. But I'm not sure that the second error follows from the first one. Several times I've managed to create the mesh without first error, but still the second one appeared. I have also tried to change blockMesh cell number and to use createPatch, but nothing helped.
Anyhow, I'll try again by following your suggestion. Thanks.
Dejan
Old   December 18, 2012, 19:26
Qiang Zhou
michael1023 is on a distinguished road
Originally Posted by maddalena View Post
Hello Dejan,
mad
Hi, Maddalena.
I have the same problem (Error in coupled point location), could you do me a favor to solve this error? Thank you very much.
If I use the createPatch, there is another error happening as below.
Attempt to cast type patch to type cyclic
From function refCast<To>(From&)
in file lnInclude/typeInfo.H at line 114.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::cyclicPolyPatch::neighbPatchID() const in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#3 Foam::cyclicPolyPatch::calcGeometry(Foam::PstreamB uffers&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 FoamlyBoundaryMesh::calcGeometry() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 FoamlyMesh::addPatches(Foam::List<FoamlyPa tch*> const&, bool) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/createPatch"
#7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Aborted
michael1023 is offline   Reply With Quote
Old   December 19, 2012, 02:39
maddalena's Avatar
maddalena
I believe this is not due to the cyclic patch creation, but to your boundary condition definition. Check that 0/* files content matches constant/polyMesh/boundary definition.
mad
Old   December 19, 2012, 03:51
Qiang Zhou
mad
Hi, Maddalena.
Thank you for your quick reply. Before I have createPatch, I checked the boundary condition definition settings in 0/* files to match constant/polyMesh/boundary definition. However it also had the error as I showed before.
Would you like send me your 0/* files and createPatchDict to me? I wanna compare the difference between us. Or could you give me some other suggestions?
Thank you again.
Michael
Old   December 19, 2012, 04:21
maddalena's Avatar
maddalena
No, I cannot. You could post here your BC before and after the patch creation and the createPatchDict as well. I can give a look to them
Anyway: double posting is NEVER a good idea. You should be aware of this...
mad
Old   December 19, 2012, 05:11
Qiang Zhou
Hi, Maddalena.
Sorry for my discourtesy and thank you for your remind and quick reply.
The attachment is my BC and createPatchDict. I will be very appreciated if you can read them.
your sincerely
Michael
mad
Old   December 19, 2012, 05:46
maddalena's Avatar
maddalena
indeed there are some incoherency in your createPatchDict file:
        // Name of new patch
        name front_cyclic;
        // Type of new patch
        patchInfo
            type            cyclic;
            matchTolerance  0.001;
            neighbourPatch  back_cyclic;
        // How to construct: either from 'patches' or 'set'
        constructFrom patches;
        // If constructFrom = patches : names of patches. Wildcards allowed.
        patches ( front );
        name back_cyclic;
        patchInfo
            type            cyclic;
            neighbourPatch  front_cyclic;
        patches ( back );
you must use the newly created patch name as neighbor. Try to run createPatch once again and let me know.
mad
Old   December 19, 2012, 06:02
Qiang Zhou
        name front_cyclic;
        patchInfo
            type            cyclic;
        patches ( front );
        name back_cyclic;
        patchInfo
            type            cyclic;
        patches ( back );
mad
Hi, Maddalena.
Thank you a lot for your constructional suggestion. It can work well. Thank you again.
your sincerely
Michael
Old   January 31, 2013, 21:01
Qiang Zhou
        name front_cyclic;
        patchInfo
            type            cyclic;
        patches ( front );
        name back_cyclic;
        patchInfo
            type            cyclic;
        patches ( back );
mad
Hi,Maddalena.
The createPatch cannot work when I preform in OpenFOAM-1.7.1 with the same createPatchDict. The errors shows that the neighbourPatch cannot recognized. Do you have the createPatchDict in OpenFOAM-1.7.1 or suggestions for me?
Thank you.
Old   February 1, 2013, 00:36
Qiang Zhou
        name front_cyclic;
        patchInfo
            type            cyclic;
        patches ( front );
        name back_cyclic;
        patchInfo
            type            cyclic;
        patches ( back );
mad
Hi,Maddalena.
The error is shown as below
Found "neighbourPatch" entry when reading cyclic patch front_cyclic
Is this mesh already with split cyclics?
If so run a newer version that supports it, if not comment out the "neighbourPatch" entry and re-run
Thank you.
Old   February 1, 2013, 02:29
Post
  #16
maddalena's Avatar
maddalena
Hello, have you try this?
anyway, this is the patch definition required for any openFoam before 2.0:
patches
        name cyclicSides;
    dictionary
            type cyclic;
        // Optional: explicitly set transformation tensor.
            // Used when matching and synchronising points.
            //transform translational;
            //separationVector (1 0 0);
              rotationAxis (1 0 0);
        patches (right left);
        // If constructFrom = set : name of faceSet
        set f0;
Old   February 1, 2013, 23:48
Qiang Zhou
patches
        name cyclicSides;
    dictionary
            type cyclic;
        set f0;
Hi,Maddalena.
I have tried this method.
But it didn't work.
I think there are some difference in createPatchDict between OF-2.1.1 and OF-1.7.1.
Meanwhile, neighbourPatch cannot recognized in OF-1.7.1.
I still try the other methods. Anyway, thank you very much.
Old   April 28, 2013, 21:23
pooyan
sam1364 is on a distinguished road
Hi Michael,
I have the same issue defining cyclic B.C in OpenFoam version 2.1.0. can you please let me know how the createpatchDict should look like? and any other tricky part related to the version 2.1.0 of OpenFoam in doing so?
Thanks,
Pooyan
Hi, Maddalena.
your sincerely
Michael
sam1364 is offline   Reply With Quote
Old   April 30, 2013, 10:12
maddalena's Avatar
maddalena
you should have an example under application/utilities/mesh/manipulation/createPatch. Anyway: https://github.com/OpenFOAM/OpenFOAM...reatePatchDict
Old   May 1, 2013, 22:36
Qiang Zhou
Hi, Sam
you can read the example of createPatch as below:
patches
name cyclicSides;
dictionary
type cyclic;
set f0;
Parallel refineMesh with Cyclic Boundaries mchurchf OpenFOAM 8 December 22, 2018 11:11
Problem with cyclic boundaries in Openfoam 1.5 fs82 OpenFOAM 36 January 7, 2015 00:31
mapFields - Changing from turbulentInlet/outlet boundaries to cyclic boundaries TianC OpenFOAM Pre-Processing 8 January 16, 2013 05:15
Wrong wall distance with cyclic boundaries sebastian OpenFOAM Bugs 4 October 31, 2012 10:24
Problems with cyclic boundaries in faMeshDefinition and surfactantFoam safre OpenFOAM 3 December 12, 2011 07:56
