problem parallel processing (meshSearch, openMPI)
Old   September 10, 2012, 04:23
Angry problem parallel processing (meshSearch, openMPI)
Fabien Farella
FabienF is on a distinguished road
I want to perform a simple post-processing task (in parallel, using meshsearch).
Basically:
- each processor loops over its interior field
-> current_pt=mesh.C()[cellI];
-> U_current[cellI]=U[cellI];
- if the value of field X (here mesh.C().component(2)) is above a threshold, it looks for an offset point:
-> sup_pt=current_pt+point(0.0 , 0.0, offset);
-> idx_sup = searchEngine.findCell(sup_pt)
-> U_sup[cellI]= Uint.interpolate(sup_pt,idx_sup)
- the new field Y gets the value Y[cellI]=U_curr[cellI]-U_sup[cellI]
Here is my implementation:
meshSearch searchEngine(mesh);
interpolationCellPoint<vector> UInt(U);
vector U_sup=vector::zero;
vector U_curr=vector::zero;
point current_pt=point::zero;
point pt_sup=point::zero;
scalar offset=30.0;
forAll(mesh.C(), cellI)
U_curr=U[cellI];
if ( current_pt[2]>offset )
pt_sup=current_pt+point(0.0,0.0,offset);
Pout << " pt :x "<< current_pt << endl;
Pout << " pt sup: "<< pt_sup << endl;
List<label> idx_sup(Pstream::nProcs(),0);
List<scalar> dist_sup(Pstream::nProcs(),GREAT);
List<vector> Usup(Pstream::nProcs(),vector::zero);
idx_sup[Pstream::myProcNo()] = searchEngine.findNearestCell(pt_sup,cellI);
reduce(idx_sup,maxOp<List<label> >());
searcherSup=1000000.0;
for (int i=0; i<Pstream::nProcs() ;i++)
dist_sup[i]=mag(mesh.C()[idx_sup[i]]-pt_sup);
Pout << " pt sup found: "<< i << " "<< mesh.C()[idx_sup[i]] << " " << dist_sup[i] <<endl;
if (dist_sup[i]<searcherSup)
searcherSup=dist_sup[i];
found_sup=i;
Pout << " pt sup kept: "<< mesh.C()[idx_sup[found_sup]] << endl << endl;
if (Pstream::myProcNo()==found_sup)
Usup[Pstream::myProcNo()]=UInt.interpolate(pt_sup,idx_sup[found_sup]);
reduce(Usup,maxOp<List<vector> >());
U_sup = Usup[found_sup];
Y[cellI] = U_curr-U_sup;
Info << " U : "<< U_curr << endl;
Info << " U sup: "<< U_sup << endl;
Pout << "Finished! << endl;
It seems that the meshSearch finds the right points, but the problem is that processor2 (due to my decomposition and the offset value) finishes its task first, and the other processors seem to get stuck has soon as this happens.
(By the way, it is a simplified version of my problem. I am not trying to find offset points outside my mesh, as this sample code would suggest)
Do you have an idea why? I have been struggling for quiet a while!!!
Thanks,
Fabien
FabienF is offline   Reply With Quote
interpolation, meshsearch, mpi, parallel, postprocessing
Parallel interDyMFoam cellLevel problem tgvosk OpenFOAM Running, Solving & CFD 5 February 19, 2014 02:24
Parallel processing problem newbie29 OpenFOAM Running, Solving & CFD 1 June 22, 2012 04:23
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
bubbly flow and parallel processing mvee FLUENT 0 September 12, 2007 05:08
About parallel processing in Linux tuks CFX 10 August 8, 2005 08:22
