problem with using uniformFixedValue in OF 2.1.1 |
September 13, 2012, 20:27 |
Amin Shariat KHah
Hi dear Foamers
I wanna use timevarying BC in OF 2.1.1 My solver is icoFoam and I use ubuntu 12.04 0\U file is: Code:
inlet { type uniformFixedValue uniformValue table ( ( 0 0.0) (100 10.0) ); } Reading field U Code:
--> FOAM FATAL IO ERROR: keyword uniformValue is undefined in dictionary "/home/amin/OpenFOAM/amin-2.1.1/run/arterioleNewtonian/0/U::boundaryField::inlet" file: /home/amin/OpenFOAM/amin-2.1.1/run/arterioleNewtonian/0/U::boundaryField::inlet from line 25 to line 26. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 400. FOAM exiting |
September 14, 2012, 03:51 |
Amin Shariat KHah
I found my answer here:
http://www.cfd-online.com/Forums/ope...make-ramp.html I founded my fault . I should change to this for velocity: inlet { type uniformFixedValue uniformValue table ( ( 0 (0 0 0.0)) (100 (0 0 10.0)) ); } |
September 14, 2012, 09:34 |
M Mallikarjuna Reddy
hi amin,
I think you should have to change your uniformFixedValue to timeVaryingUniformFixedValue. Then it will work. Thanks Regards Mallikarjuna |
June 29, 2016, 13:22 |
Kristopher Pierson
Mallikarjuna,
TimeVaryingUniformFixedValue is an old BC that does not work in new versions of OpenFoam. |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
