How to solve a heat conduction between two different solid materials ?
Like Tree5Likes
Old   October 9, 2012, 02:41
Default How to solve a heat conduction between two different solid materials ?
Mark Huang
cremona is on a distinguished road
I'm new with OpenFoam. I'm trying to solve a simple heat conduction problem by OpenFoam "laplacian" solver, but couldn't find an exapmle about heat conduction of two different solid materials in tutorials.
So far, I can establish blockMeshDict and controlDict well (I guess), but just do not know how to set up the thermophysical property of two materials in TransportProperties and the contact resistance.
Or I just choose the wrong solver completely?
Thanks a lot...
cremona is offline   Reply With Quote
Old   October 9, 2012, 03:09
akidess's Avatar
Anton Kidess
LaplacianFoam just expects a scalar value for the diffusivity, thus it is not set up to handle varying material properties. You can easily replace the dimensionedScalar in the code by a volScalarField which you initialize using setFields (you can probably even find the necessary code here on the forum). Alternatively you can use chtMultiRegionFoam, but I think that will be more work.
- Anton
Tobi likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   October 10, 2012, 22:41
Mark Huang
Thanks,
I describe the problem in detail.
I would like to solve a heat conductuion problem, such as the structure below.
......| ...A... |
| .........B............ |
Double-line : Heat source
Solid A : Material A
Solid B : Material B
There is a contact resistance between Solid A and Solid B.
All boundaries are heat insulation.
I have set up the blockMeshDict and controlDict well, but I do not know how to set up the thermophysical properties and the contact resistance.
Could someone give me an idea of which solver I should use and which file I should set up them ?
Best Regards
Old   October 11, 2012, 07:33
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Originally Posted by cremona View Post
Thanks,
......| ...A... |
Best Regards
if you have the meshes, its very easy to set up a case with the chtMultiRegionSimpleFoam. I did that in my bachelorthesis and in a project with thermoelectric moduls. At least I had a construction to simulate like yours
have a look at the chtMultiRegionSimpleFoam tutorial.
Regards
Tobi
Tobi is offline   Reply With Quote
Old   October 15, 2012, 02:52
Mark Huang
Originally Posted by Tobi View Post
Regards
Tobi
Thanks Tobi,
I have checked chtMultiRegionSimpleFoam tutorial, but I found it is a solver for the behavior of heat transfer between "fluid and solid".
Can it also solve the heat conduction between "2 solids" ?
By the way, how about the contact resistance ?
Could I set it up in chtMultiRegionSimpleFoam solver ?
Regards,
Mark
Old   October 15, 2012, 04:07
Tobi's Avatar
Tobias Holzmann
you can solve solid/solid regions. I did it in my bachelorthesis.
To your questions with the resistance between the solids. Good question. I dont know. Maybe there are some new BC for that problem. But I am not up to date.
If you want, I can upload a testcase for 2 solid regions (2 cylinder)
Its 2 years ago that I worked with the chtMultiRegionSimpleFoam but it should work!
Regard
Tobi
Old   October 15, 2012, 04:28
Mark Huang
Regard
Tobi
Hi Tobi,
I do need your test case for reference due to I'm quite new with OpenFoam.
I very appreciate !
Besides, do you know the difference between chtMultiRegionSimpleFoam and chtMultiRegionFoam ?
Regards,
Mark
Old   October 15, 2012, 18:15
Lightbulb
Tobi's Avatar
Tobias Holzmann
first to your questions:
chtMultiRegionSimpleFoam is a steady state solver. So the time derivations are neglegted couse in a steady state solution the changes in time are zero.
The code therfor is (just for the solid regions):
        fvScalarMatrix tEqn
            -fvm::laplacian(kappa, T)
        tEqn.relax();
        tEqn.solve();
chtMultiRegionSimpleFoam solves the equation with time derivations. So you are solving a transient problem.
The code therefor is (just for the solid regions):
        tmp<fvScalarMatrix> TEqn
            fvm::ddt(rho*cp, T)
          - fvm::laplacian(kappa, T)
        TEqn().relax();
        TEqn().solve(mesh.solver(T.select(finalIter)));
If you have a look at both equations you can see that for a steady-state solution the values of cp and rho doesn't matter.
Maybe easier?
If you have a look at the solver "scalarTransportFoam" there is the following implemented:
            solve
                fvm::ddt(T)
              + fvm::div(phi, T)
              - fvm::laplacian(DT, T)
where T is a simple scalar (like the temperature).
You can modify this solver by comment out the first both terms:
            solve
              //  fvm::ddt(T)
              //+ fvm::div(phi, T)
Now its like the chtMultiRegionSimpleFoam for "ONE" region. Now you have to implement the second region and the
interaction between these two regions. But you are new to OpenFOAM so I think you wanna use chtMultiRegionSimpleFoam
Info
My old case does not work anymore and I had to make it working with OF-2.1.x again.
I saw new thermodynamic libs for the solid region. In the new version you are able
to set directional solid values like conductivity for (x,y,z). Have a look at the file
thermoType constSolidThermo;
//thermoType isotropicKSolidThermo;
//thermoType directionalKSolidThermo;
//thermoType solidMixtureThermo<multiComponentSolidMixture<exponentialSolidTransport<constSolidRad<exponentialSolidThermo<constRho>>>>>;
Testcase
I used a simple test-case in my bachelorthesis to check the solution of the solver.
Therefor I used two pipes and a fixed inner and outer temperature. With that I calculated the heatflux q and compared it with the empirical model:
T_inner = 773K
T_outer = 303K
--> q empirical = 214,16 W
--> q_simulation = 213,48 W
--> T_interface_empirical = 552,45 K
--> T_interface_numerical = 551,09 K
Maybe the solution was not converged enough (I was a beginner at that time). But its very accurate.
Further more the empirical equation uses a logarithmic function for the temperature, which can be also shown with the
chart added in the attachment.
Solving for solid region kieselgur
DICPCG:  Solving for T, Initial residual = 0.00087073769, Final residual = 1.1952783e-05, No Iterations 2
Min/max T:434.01808 773
Solving for solid region glaswolle
DICPCG:  Solving for T, Initial residual = 0.00079268991, Final residual = 1.0810456e-05, No Iterations 2
Min/max T:303 437.02853
ExecutionTime = 6.07 s  ClockTime = 6 s
Time = 242
How to run the testcase
1. Download the tar file
2. untar the file
3. move it to your $FOAM_RUN folder
4. switch into the directory
5. ./solve
6. paraview
7. open the two files build by solve.sh
enjoy
Regard
Tobi
PS: Plot of residual and temperature curvature is attached
PPS: I am very tierd now; good night everybody
Case is updated 19.10.2012
Thank you Mark for telling me the problem
File Type: gz chtMultiRegionSimpleFoam_case_cremona.tar.gz (7.4 KB, 435 views)
Old   October 16, 2012, 05:02
Mark Huang
Thanks Tobi,
I got your case, and I'v check it already.
I would like to ask another question.
In my case , I establish different structure with yours, so I have to mesh it.
However, I couldn't generate a file "cellToRegion" in the \0 directory.
How can I create it?
Thanks a lot..
Regards
Mark
p.s. The platform I run openFoam is in Windows System. I purchased a software which is named OpenFlow and it is a native Windows port of OpenFOAM 2.1.x. by Symscape company.
Old   October 16, 2012, 08:00
Tobi's Avatar
Tobias Holzmann
Thanks Tobi,
Thanks a lot..
Regards
Mark
is that file necessary?
I think that was a file I created with snappyHexMesh in a case befor
Delete it please I think it should work without.
Tobi
PS: I know windows operating systems/software for openfoam too but I am an oldschool terminal/script user
Old   October 16, 2012, 08:10
Tobi's Avatar
Tobias Holzmann
- Anton
Notice
like Anton mentioned, the laplacianFoam solves the scalarField for the
temperature field with a scalar conductivity. The chtMultiRegionSimpleFoam is able
to use a direction depended conductivity by using the thermodynamic models
which are included in the chtMultiRegionFoam for the solid regions.
Old   October 16, 2012, 09:02
akidess's Avatar
Anton Kidess
Tobi, your last post doesn't make sense to me. Temperature will never be a vector, so why use fvVectorMatrix?
Old   October 16, 2012, 10:22
Tobi's Avatar
Tobias Holzmann
You are right.
I messed up a few things ...
Uppssss ...
Wanted to make it possible to use directional depended thermal conductivity, couse in the version 1.7, there are no model for that.
But now I saw that you can use the thermodynamic model for that!
Thanks for your comment.
Old   October 18, 2012, 20:28
Mark Huang
Tobi
Hi Tobi,
There is still a problem with running your case. After I ran the case by chtMultiRegionSimpleFoam solver, I got an error message
" patch type 'patch' not type 'directMappedPatchBase' for patch kieselgur_to_glaswolle of field T in file "D:/example/0/T" "
Then, I changed the relavent keyword 'patch' to 'directMappedPatchBase' in your case and my case, but again I got an error message
" patch type 'genericPatch' not type 'directMappedPatchBase' for patch kieselgur_to_glaswolle of field T in file "D:/example/0/T" "
Now, I have no ideas to cope with this problem.
Do you have any ideas about it? Or anyone can give me some suggestion.
Thanks....
Regards,
Mark
Old   October 19, 2012, 03:28
Tobi's Avatar
Tobias Holzmann
Hi Tobi,
Thanks....
Regards,
Mark
Oh sorry.
That problem is coused by the patch type in your
/constant/SOLIDREGION/polyMesh/boundary
I ll have a look at that now.
One moment
Old   October 19, 2012, 03:55
Tobi's Avatar
Tobias Holzmann
Hi Tobi,
Mark
Hi Mark,
please download the tar.gz file again. I forget a file called "boundary.backup" in the /constant/kieselgur/polyMesh" folder.
To clear your mind
If you use chtMultiRegion solver you are using several domains which
must be connected. So the interfaces between two solid regions are
of patchType
type        mappedWall;
But thats not all you have do modify.
Normally a patch type looks like that one:
myPatch
    type               patch;
    nFaces           4;
    startFace       168;
for the interfaces in chtMulti solver you have to use that patch
myPatch1_to_myPatch2
    type                   mappedWall;
    nFaces               10;
    startFace           222;
    sampleMode      nearestPatchFace;
    sampleRegion    mySolid2;
    samplePatch      myPatch1_to_myPatch2;
    offsetMode        uniform;
    offset                ( 0 0 0 );
Again
You can make your mesh by typing the command:
blockMesh -region glaswolle
blockMesh -region kieselgur
in your terminal. After that compare the files:
constant/glaswolle/polyMesh/boundary
constant/glaswolle/polyMesh/boundary.backup
constant/kieselgur/polyMesh/boundary
constant/kieselgur/polyMesh/boundary.backup
I think that makes everything clear.
It should be possible to set the boundary condition in blockMeshDict
but I dont know how to do that.
The case should run now by using
./solve
Regard
Tobi
Old   November 5, 2012, 15:53
Romain
nakor is on a distinguished road
Regard
Tobi
I have the exact same problem : how to simulate a contact resistance between two solids.
It seems to me that the only available boundary condition in chtMultiRegionFoam for interface between two solids, or a solid and a fluid will always be :
			type            compressible::turbulentTemperatureCoupledBaffleMixed;
		        neighbourFieldName T;
		        K               solidThermo;
		        KName           none;
		        value           uniform 321.34;
it will assume a perfect contact between the two solids, or calculate the heat transfer coefficient (explained here and here )
Coming from this analysis, I have three possibilities
-a small region between the two solids, which will simulates the contact resistance (Rth=e/lambda*S, with low e, and really low lambda), but it could be difficult for the most complex geometries
-use swak4foam. But it does not seems to be able to do what I want... Still looking on that.
-modify the boundary condition such that the boundary will not impose the same temperature on each side (source code here)
anyway if someone has any ideas or a few hints it will surely speed up the process
nakor is offline   Reply With Quote
Old   November 5, 2012, 17:14
Tobi's Avatar
Tobias Holzmann
                K               solidThermo;
                KName           none;
Yes I think so too!
sounds good but I am withyou! For complex geometries it would be very hard to do it
Hmmm I think its possible to do that. But like I told befor, its two years ago that I worked with that solver
Well that sounds good.
I can create a new BC (but not now - in Dez/Jan maybe, if I dont forget it and have time)... the problem I think is, how would you calculate your resistance?
If you put two plates together you have a resistance thats clear, but what value would you set or is it possible to calculate it with some empiric equations which depend on the surface?
Tobi
Old   November 5, 2012, 18:01
Romain
I am not sure that it will be possible with swak4foam since I am just starting with this nice tool, but it seems promising.
If we are only considering one boundary between two solids, namely solid 1 and solid 2, and one heat flux through said boundary, we will have one surface we will be hotter than the other (Tside1=Tside2+flux*Rth)
Thus, one boundary which could work will be
Side2
type groovyBC;
value uniform Tinit;
valueExpression "Tside1+DT*q";
variables "Tside1{side1/solid1}=average(T);DT=cst;q=?";
The main problem here would be to determine the heat flux which go through the boundary... It could be obtain with something like q = DeltaT* (lambda*S/e) for a really small e near the boundary.
But I do not know (yet) how to do that.
I do like this approach too, but the source code does not seem that easy to understand, I will need to spend some time on it.
I think the easiest way to go is to let the user define the resistance in Km2/W between two surfaces.
After that, the boundary will have to maintain a constant heat flow on each side of the boundary, but the temperature on each side of this boundary will be different depending on the specified thermal resistance.
Old   November 9, 2012, 08:32
Romain
After some research, swak4foam does not seems to be adaptated to our problems.
It will average the temperature on each patch, so I will lose the spatial informations.
But I had an other idea before attempting to look into the boundary condition source code.
It seem that a baffle could answer to my problem. If I understand correctly how it is working, it could create a small region between the two solids, which will simulates the contact resistance with Rth=e/lambda*S
zone1_to_zone2
              type            directMappedWallVariableThickness;
              // This thickness is used if the baffle is 1D.
              thickness       uniform 0.005;
Does anyone have any previous experiense with those thermal baffles ?
thermal baffles release note
edit:Thermal baffle is perfect! But it is not adapted to mappedPatch, only to genericPatch
It seem that I will have to look inside the code of turbulentTemperatureCoupledBaffleMixed and try to modify it a bit..
heat conduction, heat transfer, thermophysicalproperties, transportproperties
Heat transfer (conduction) between two pipes shields FLUENT 14 February 3, 2016 07:45
heat conduction in solid and convection in flow kunal FLUENT 3 February 29, 2012 04:42
Heat conduction through Sand or pulverised materials dwqi0419 CFX 6 May 26, 2010 04:53
heat conducting in a solid domain Rogerio Fernandes Brito FLUENT 0 March 18, 2008 17:25
Heat conduction between contacting solid materials Ken Adams FLUENT 5 January 18, 2007 18:14
