How to solve a heat conduction between two different solid materials ? |
October 9, 2012, 02:41 |
Mark Huang
I'm new with OpenFoam. I'm trying to solve a simple heat conduction problem by OpenFoam "laplacian" solver, but couldn't find an exapmle about heat conduction of two different solid materials in tutorials. So far, I can establish blockMeshDict and controlDict well (I guess), but just do not know how to set up the thermophysical property of two materials in TransportProperties and the contact resistance. Or I just choose the wrong solver completely? Thanks a lot... |
October 9, 2012, 03:09 |
Anton Kidess
Rep Power: 29 |
LaplacianFoam just expects a scalar value for the diffusivity, thus it is not set up to handle varying material properties. You can easily replace the dimensionedScalar in the code by a volScalarField which you initialize using setFields (you can probably even find the necessary code here on the forum). Alternatively you can use chtMultiRegionFoam, but I think that will be more work.
- Anton
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
October 10, 2012, 22:41 |
Mark Huang
Thanks,
I describe the problem in detail. I would like to solve a heat conductuion problem, such as the structure below. ......---==--- ......| ...A... | ------------------- | .........B............ | ------------------- Double-line : Heat source Solid A : Material A Solid B : Material B There is a contact resistance between Solid A and Solid B. All boundaries are heat insulation. I have set up the blockMeshDict and controlDict well, but I do not know how to set up the thermophysical properties and the contact resistance. Could someone give me an idea of which solver I should use and which file I should set up them ? Best Regards |
October 11, 2012, 07:33 |
#4 | |
Tobias Holzmann
Rep Power: 51 |
if you have the meshes, its very easy to set up a case with the chtMultiRegionSimpleFoam. I did that in my bachelorthesis and in a project with thermoelectric moduls. At least I had a construction to simulate like yours have a look at the chtMultiRegionSimpleFoam tutorial. Regards Tobi |
October 15, 2012, 02:52 |
#5 | |
Mark Huang
Thanks Tobi, I have checked chtMultiRegionSimpleFoam tutorial, but I found it is a solver for the behavior of heat transfer between "fluid and solid". Can it also solve the heat conduction between "2 solids" ? By the way, how about the contact resistance ? Could I set it up in chtMultiRegionSimpleFoam solver ? Regards, Mark |
October 15, 2012, 04:07 |
Tobias Holzmann
Rep Power: 51 |
you can solve solid/solid regions. I did it in my bachelorthesis. To your questions with the resistance between the solids. Good question. I dont know. Maybe there are some new BC for that problem. But I am not up to date. If you want, I can upload a testcase for 2 solid regions (2 cylinder) Its 2 years ago that I worked with the chtMultiRegionSimpleFoam but it should work! Regard Tobi |
October 15, 2012, 04:28 |
#7 | |
Mark Huang
Hi Tobi, I do need your test case for reference due to I'm quite new with OpenFoam. I very appreciate ! Besides, do you know the difference between chtMultiRegionSimpleFoam and chtMultiRegionFoam ? Regards, Mark |
October 15, 2012, 18:15 |
Tobias Holzmann
Rep Power: 51 |
first to your questions: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - chtMultiRegionSimpleFoam is a steady state solver. So the time derivations are neglegted couse in a steady state solution the changes in time are zero. The code therfor is (just for the solid regions): Code:
fvScalarMatrix tEqn ( -fvm::laplacian(kappa, T) ); tEqn.relax(); tEqn.solve(); The code therefor is (just for the solid regions): Code:
tmp<fvScalarMatrix> TEqn ( fvm::ddt(rho*cp, T) - fvm::laplacian(kappa, T) ); TEqn().relax(); TEqn().solve(mesh.solver(T.select(finalIter))); If you have a look at both equations you can see that for a steady-state solution the values of cp and rho doesn't matter. Maybe easier? - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - If you have a look at the solver "scalarTransportFoam" there is the following implemented: Code:
solve ( fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(DT, T) ); You can modify this solver by comment out the first both terms: Code:
solve ( // fvm::ddt(T) //+ fvm::div(phi, T) - fvm::laplacian(DT, T) ); interaction between these two regions. But you are new to OpenFOAM so I think you wanna use chtMultiRegionSimpleFoam Info - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - My old case does not work anymore and I had to make it working with OF-2.1.x again. I saw new thermodynamic libs for the solid region. In the new version you are able to set directional solid values like conductivity for (x,y,z). Have a look at the file Code:
thermoType constSolidThermo; //thermoType isotropicKSolidThermo; //thermoType directionalKSolidThermo; //thermoType solidMixtureThermo<multiComponentSolidMixture<exponentialSolidTransport<constSolidRad<exponentialSolidThermo<constRho>>>>>; - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - I used a simple test-case in my bachelorthesis to check the solution of the solver. Therefor I used two pipes and a fixed inner and outer temperature. With that I calculated the heatflux q and compared it with the empirical model: T_inner = 773K T_outer = 303K --> q empirical = 214,16 W --> q_simulation = 213,48 W --> T_interface_empirical = 552,45 K --> T_interface_numerical = 551,09 K Maybe the solution was not converged enough (I was a beginner at that time). But its very accurate. Further more the empirical equation uses a logarithmic function for the temperature, which can be also shown with the chart added in the attachment. Code:
Solving for solid region kieselgur DICPCG: Solving for T, Initial residual = 0.00087073769, Final residual = 1.1952783e-05, No Iterations 2 Min/max T:434.01808 773 Solving for solid region glaswolle DICPCG: Solving for T, Initial residual = 0.00079268991, Final residual = 1.0810456e-05, No Iterations 2 Min/max T:303 437.02853 ExecutionTime = 6.07 s ClockTime = 6 s Time = 242 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 1. Download the tar file 2. untar the file 3. move it to your $FOAM_RUN folder 4. switch into the directory 5. ./solve 6. paraview 7. open the two files build by solve.sh enjoy - - - - - - - - - - - Regard Tobi PS: Plot of residual and temperature curvature is attached PPS: I am very tierd now; good night everybody Case is updated 19.10.2012 Thank you Mark for telling me the problem Last edited by Tobi; October 19, 2012 at 03:58. Reason: Updated the case |
October 16, 2012, 05:02 |
Mark Huang
Thanks Tobi,
I got your case, and I'v check it already. I would like to ask another question. In my case , I establish different structure with yours, so I have to mesh it. However, I couldn't generate a file "cellToRegion" in the \0 directory. How can I create it? Thanks a lot.. Regards Mark p.s. The platform I run openFoam is in Windows System. I purchased a software which is named OpenFlow and it is a native Windows port of OpenFOAM 2.1.x. by Symscape company. |
October 16, 2012, 08:00 |
#10 | |
Tobias Holzmann
Rep Power: 51 |
Hi, is that file necessary? I think that was a file I created with snappyHexMesh in a case befor Delete it please I think it should work without. Tobi PS: I know windows operating systems/software for openfoam too but I am an oldschool terminal/script user |
October 16, 2012, 08:10 |
#11 | |
Tobias Holzmann
Rep Power: 51 |
Notice - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - like Anton mentioned, the laplacianFoam solves the scalarField for the temperature field with a scalar conductivity. The chtMultiRegionSimpleFoam is able to use a direction depended conductivity by using the thermodynamic models which are included in the chtMultiRegionFoam for the solid regions. Last edited by Tobi; October 16, 2012 at 10:37. Reason: Messed up things!!! |
October 16, 2012, 09:02 |
#12 |
Anton Kidess
Rep Power: 29 |
Tobi, your last post doesn't make sense to me. Temperature will never be a vector, so why use fvVectorMatrix?
October 16, 2012, 10:22 |
#13 | |
Tobias Holzmann
Rep Power: 51 |
I messed up a few things ... Uppssss ... Wanted to make it possible to use directional depended thermal conductivity, couse in the version 1.7, there are no model for that. But now I saw that you can use the thermodynamic model for that! Thanks for your comment. Last edited by Tobi; October 16, 2012 at 10:35. Reason: Last edit |
October 18, 2012, 20:28 |
#14 | |
Mark Huang
Hi Tobi, There is still a problem with running your case. After I ran the case by chtMultiRegionSimpleFoam solver, I got an error message " patch type 'patch' not type 'directMappedPatchBase' for patch kieselgur_to_glaswolle of field T in file "D:/example/0/T" " Then, I changed the relavent keyword 'patch' to 'directMappedPatchBase' in your case and my case, but again I got an error message " patch type 'genericPatch' not type 'directMappedPatchBase' for patch kieselgur_to_glaswolle of field T in file "D:/example/0/T" " Now, I have no ideas to cope with this problem. Do you have any ideas about it? Or anyone can give me some suggestion. Thanks.... Regards, Mark |
October 19, 2012, 03:28 |
#15 | |
Tobias Holzmann
Rep Power: 51 |
That problem is coused by the patch type in your Code:
/constant/SOLIDREGION/polyMesh/boundary One moment |
October 19, 2012, 03:55 |
#16 | |
Tobias Holzmann
Rep Power: 51 |
Hi Mark, please download the tar.gz file again. I forget a file called "boundary.backup" in the /constant/kieselgur/polyMesh" folder. To clear your mind - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - If you use chtMultiRegion solver you are using several domains which must be connected. So the interfaces between two solid regions are of patchType Code:
type mappedWall; Normally a patch type looks like that one: Code:
myPatch { type patch; nFaces 4; startFace 168; } Code:
myPatch1_to_myPatch2 { type mappedWall; nFaces 10; startFace 222; sampleMode nearestPatchFace; sampleRegion mySolid2; samplePatch myPatch1_to_myPatch2; offsetMode uniform; offset ( 0 0 0 ); } - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - You can make your mesh by typing the command: Code:
blockMesh -region glaswolle blockMesh -region kieselgur Code:
constant/glaswolle/polyMesh/boundary constant/glaswolle/polyMesh/boundary.backup constant/kieselgur/polyMesh/boundary constant/kieselgur/polyMesh/boundary.backup It should be possible to set the boundary condition in blockMeshDict but I dont know how to do that. The case should run now by using Code:
./solve Tobi |
November 5, 2012, 15:53 |
#17 | |
Romain
It seems to me that the only available boundary condition in chtMultiRegionFoam for interface between two solids, or a solid and a fluid will always be : Code:
type compressible::turbulentTemperatureCoupledBaffleMixed; neighbourFieldName T; K solidThermo; KName none; value uniform 321.34; Coming from this analysis, I have three possibilities -a small region between the two solids, which will simulates the contact resistance (Rth=e/lambda*S, with low e, and really low lambda), but it could be difficult for the most complex geometries -use swak4foam. But it does not seems to be able to do what I want... Still looking on that. -modify the boundary condition such that the boundary will not impose the same temperature on each side (source code here) anyway if someone has any ideas or a few hints it will surely speed up the process |
November 5, 2012, 17:14 |
#18 | ||||
Tobias Holzmann
Rep Power: 51 |
I can create a new BC (but not now - in Dez/Jan maybe, if I dont forget it and have time)... the problem I think is, how would you calculate your resistance? If you put two plates together you have a resistance thats clear, but what value would you set or is it possible to calculate it with some empiric equations which depend on the surface? Tobi |
November 5, 2012, 18:01 |
#19 | ||
Romain
If we are only considering one boundary between two solids, namely solid 1 and solid 2, and one heat flux through said boundary, we will have one surface we will be hotter than the other (Tside1=Tside2+flux*Rth) Thus, one boundary which could work will be Code:
Side2 { type groovyBC; value uniform Tinit; valueExpression "Tside1+DT*q"; variables "Tside1{side1/solid1}=average(T);DT=cst;q=?"; } But I do not know (yet) how to do that. Quote:
I think the easiest way to go is to let the user define the resistance in Km2/W between two surfaces. After that, the boundary will have to maintain a constant heat flow on each side of the boundary, but the temperature on each side of this boundary will be different depending on the specified thermal resistance. |
November 9, 2012, 08:32 |
#20 |
Romain
After some research, swak4foam does not seems to be adaptated to our problems.
It will average the temperature on each patch, so I will lose the spatial informations. But I had an other idea before attempting to look into the boundary condition source code. It seem that a baffle could answer to my problem. If I understand correctly how it is working, it could create a small region between the two solids, which will simulates the contact resistance with Rth=e/lambda*S Code:
zone1_to_zone2 { type directMappedWallVariableThickness; // This thickness is used if the baffle is 1D. thickness uniform 0.005; } thermal baffles release note edit:Thermal baffle is perfect! But it is not adapted to mappedPatch, only to genericPatch It seem that I will have to look inside the code of turbulentTemperatureCoupledBaffleMixed and try to modify it a bit.. Last edited by nakor; November 9, 2012 at 14:39. |
heat conduction, heat transfer, thermophysicalproperties, transportproperties |
Heat transfer (conduction) between two pipes | shields | FLUENT | 14 | February 3, 2016 07:45 |
heat conduction in solid and convection in flow | kunal | FLUENT | 3 | February 29, 2012 04:42 |
Heat conduction through Sand or pulverised materials | dwqi0419 | CFX | 6 | May 26, 2010 04:53 |
heat conducting in a solid domain | Rogerio Fernandes Brito | FLUENT | 0 | March 18, 2008 17:25 |
Heat conduction between contacting solid materials | Ken Adams | FLUENT | 5 | January 18, 2007 18:14 |
