How to avoid the generations of incorrectly oriented faces when morphing mesh |
October 21, 2012, 23:16 |
Fumiya Nozaki
Rep Power: 18 |
Hi All,
I'm trying to morph the mesh using the solver displacementLaplacian. My issue is that the incorrectly oriented faces are generated at the points between the fixed points(pointDisplacement=(0 0 0)) and the movable points. My settings in the dynamicMeshDict are as follows: dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ( "libfvMotionSolvers.so" ); solver displacementLaplacian; diffusivity quadratic inverseDistance 1(movingWall); What solvers and settings should I use to avoid the generations of these faces? Thanks, Fumiya |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 06:30 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
