Do I need to change mechnical properties after using transformpoint scale utility?
Old   November 1, 2012, 22:31
Default Do I need to change mechnical properties after using transformpoint scale utility?
Sangeeta
Sargam05 is on a distinguished road
Hello everyone,
I am solving a case for 3D cube geometry. First, I have created cube mesh for 1mX1mX1m dimension then transferred the geometry to smaller scale (0.00005, 0.00005, 0.00005) by using transformPoint scale utility. I am using mechanical and thermal properties (e.g. Youngs modulus, conductivity, specific heat etc.) for the case.
Do I need to change the dimensions of mechanical and thermal properties after reducing mesh size.
For example: E = 210 X 10^9 N/m^2
Since this value is in "m", if I change cube dimensions in "mm" should it be
E = 210 X 10^3 N/mm^2 ?
Does anyone have any idea about it?
Best regards,
Sangeeta
Sargam05 is offline   Reply With Quote
Old   November 2, 2012, 02:47
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hello Sangeeta,
OpenFOAM will use meters for all it's computations (if SI units are specified in $HOME/OpenFOAM/OpenFOAM-2.1.x/etc/controlDict), so all your material properties have to be specified in the usual SI unit. So I would expect you just keep E = 210 X 10^9 N/m^2, regardless of the size of your problem.
Regards,
Tom
tomf is offline   Reply With Quote
Old   November 2, 2012, 11:41
Sangeeta
Originally Posted by tomf View Post
Hello Sangeeta,
Regards,
Tom
Hi Tom,
Thank you for the reply. Do you think that it will not going to affect final results if I do not change mechanical and thermal properties in mm?
Best regards,
Sangeeta
Old   November 3, 2012, 06:19
Tom Fahner
Originally Posted by Sargam05 View Post
Hi Tom,
Best regards,
Sangeeta
Hi Sangeeta,
This section in the userguide basically explains the role of dimensions:
http://www.openfoam.org/docs/user/ba...hp#dx18-100002
So if you plan to use SI units, use default SI units for properties i.e. kg, m, s, K, kgmol, A, cd or combinations thereof. For your problem make sure that the dimensions are specified in meters as well (0.005 for 5 mm). OpenFOAM will not know about millimeters, it only knows meters.
Regards,
Tom
Old   November 8, 2012, 11:35
Sangeeta
Hi Tom,
Thank you for the reply. I appreciate it!
Sangeeta
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
How to find a good time scale strategy? StefanG CFX 19 June 8, 2012 08:41
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
How to change the scale before plotting student Siemens 1 August 15, 2006 05:35
