std::ceil fails when using #calc in blockMeshDict
Like Tree1Likes
  • 1 Post By GerhardHolzinger
Old   June 10, 2018, 10:25
Default std::ceil fails when using #calc in blockMeshDict
Axel
Illmatic is on a distinguished road
Hi everybody,
I am trying to calculate the appropiate number of cells in a blockMeshDict using the #calc operation.
Basically what I am doing is this:
x1		1.7;
y1		2.1;
x2		2.1;
y2		2.05;
x3		2.5;
y3		2.3;
nBlock1XCells	20;
nBlock1YCells	#calc "std::ceil((y1 - y2) * 20)";
Unfortunatly this fails with the error message:
/home/fiedler/OpenFOAM/ThirdParty-v1712/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/limits:1601:7: internal compiler error: Illegal instruction
max() _GLIBCXX_USE_NOEXCEPT { return __FLT_MAX__; }
0xac5ddf crash_signal
/home/pgh/OpenFOAM/ThirdParty-1706/gcc-6.3.0/gcc/toplev.c:333
Please submit a full bug report,
with preprocessed source if appropriate.
Please include the complete backtrace with any bug report.
See <http://gcc.gnu.org/bugs.html> for instructions.
/home/fiedler/OpenFOAM/OpenFOAM-v1712/wmake/rules/General/transform:28: recipe for target 'Make/linux64Gcc63DPInt32Opt/codeStreamTemplate.o' failed
make: *** [Make/linux64Gcc63DPInt32Opt/codeStreamTemplate.o] Error 1
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/_6461bf4ad58cf530a2ae18008262b8b0fd99eb82/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_6461bf4ad58cf530a2ae18008262b8b0fd99 eb82.so"
file: /mnt/c/Users/fiedl/OneDrive/OF_Cases/neuralNetwork/mesh/system/blockMeshDict
From function static void (* Foam::functionEntries::codeStream::getFunction(con st Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
in file db/dictionary/functionEntries/codeStream/codeStream.C at line 219.
FOAM exiting
What am I doing wrong?
Best regards,
Axel
Illmatic is offline   Reply With Quote
Old   December 3, 2019, 10:14
bartimore is on a distinguished road
I have the same error, but the problem is slightly more general. For me the error comes from using #calc in the first place. Even simple multiplications result in the same error
bartimore is offline   Reply With Quote
Old   December 4, 2019, 07:02
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
You need to use your variables properly. The rules of OpenFOAM's macro expansion apply.
NZ4  #calc "std::ceil( ($Z4 - $Z3) / $dz )";
HPE likes this.
GerhardHolzinger is offline   Reply With Quote
Old   December 29, 2019, 17:04
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
FYI// The new #eval expression replacing #calc is pretty powerful and much more faster than #calc //FYI
HPE is offline   Reply With Quote
Writing a if loop in the blockMeshDict file eroussel OpenFOAM Programming & Development 0 April 20, 2018 11:39
[blockMesh] blockMesh with parametric mesh. Unusual and unseen problem 13msmemusman OpenFOAM Meshing & Mesh Conversion 1 June 13, 2016 02:25
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 16:16
cannot converge a pimpleFoam simulation iper88 OpenFOAM Running, Solving & CFD 1 November 26, 2015 08:04
[blockMesh] Cylindrical mesh with an odd number of circumferential cells Eldor OpenFOAM Meshing & Mesh Conversion 1 April 16, 2015 04:21
