Test Case: Laminar Flow Between Rotating Concentric Cylinders
View Poll Results: Do you regularly use tet meshes with triangular prisms for BL resolution in OpenFOAM?
Yes 2 40.00%
No 3 60.00%
Voters: 5. You may not vote on this poll
Old   August 6, 2009, 15:38
Default Test Case: Laminar Flow Between Rotating Concentric Cylinders
Mike Ebert
ebertmp is on a distinguished road
I have been working on a simple test problem involving laminar flow between a rotating and non-rotating cylinder (see attached file). Specifically I used simpleFoam while setting the turbulence model to laminar. This problem was chosen because it has an exact analytical solution with which to make comparisons. Grid convergence studies were done using a series of 4 hexahedral and 4 tetrahedral meshes. A comparison is also made with results from Fluent using the exact same meshes.
In summary the results show that the OpenFOAM prediction of the torque using the series of tet meshes DOES NOT appear to converge to the exact solution even though Fluent does. Of course "user error" can not be completely ruled out and so I would be glad to provide my OpenFOAM case directories to anyone interested.
Does anyone else have an example of this kind of behavior?
ebertmp is offline   Reply With Quote
Old   August 8, 2009, 06:50
Default Regularly using tet dominated meshes?
Mike Ebert
Is anyone regularly using multi-element meshes (tets + triangular prisms for boundary layer resolution) in OpenFOAM for incompressible flow simulations with success?
Thanks
--- Please participate in the poll at the beginning of this thread ---
Old   August 8, 2009, 09:17
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Hi, ebertmp,
Could you please send me the OpenFOAM case? I am interested in this case and would like to play with it. Thanks!
Pei
phsieh2005@yahoo.com
phsieh2005 is offline   Reply With Quote
Old   August 10, 2009, 19:12
Default Case file links
Mike Ebert
For anyone interested, the following links can be used to download my case directories. If you have more success than I did getting the correct answer using the tetrahedral meshes I would really appreciate feedback.
HexMesh_Coarse
HexMesh_Medium
HexMesh_Fine
HexMesh_Finest
TetMesh_Coarse
TetMesh_Medium
TetMesh_Fine
TetMesh_Finest
Thanks!
P.S. - These are setup for version 1.6.
Old   December 3, 2012, 11:54
wided
wiedangel is on a distinguished road
Hi Ebertmp.
I canīt get access to your cases, I would like also to test a transient solver which I am developing on your case. Could you please provide your OF cases as I can compare with an analytic solution.
Best regards
wiedangel is offline   Reply With Quote
accuracy cylinder tet
Drag of a sphere in laminar flow harly OpenFOAM Running, Solving & CFD 1 February 4, 2009 06:27
Laminar flow in species transport model? Neha Rao FLUENT 7 February 25, 2006 02:23
Viscous Compressible Flow Mohammad Main CFD Forum 1 December 13, 2005 11:51
Test for a laminar flow in axisymmetric nozzle Victor Main CFD Forum 0 November 30, 2005 10:51
complex geometery as a test case for laminar flow code Morteza Marivani Main CFD Forum 1 December 7, 1999 04:33
