Shocktube in OpenFoam
Old   October 17, 2011, 14:53
Default Shocktube in OpenFoam
Alexander
foamer is on a distinguished road
Hi
I am having problems with the shocktube tutorial.
There is in my interest to specify conditions on both sides on the Diaphragm, and henceforth run it.
I am not experienced in OpenFoam and hence not good at interpreting error messages.
The following error message appear when i was running the tutorial:
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo <eConstThermo<perfectGas>>>>>
--> FOAM FATAL IO ERROR:
keyword sides is undefined in dictionary "/home/user/OpenFOAM/user-1.7.1/run/tutorials01/compressible/rhoCentralFoam/shockTube/0/p::boundaryField"
file: /home/user/OpenFOAM/user-1.7.1/run/tutorials01/compressible/rhoCentralFoam/shockTube/0/p::boundaryField from line 24 to line 30.
From function dictionary::subDict(const word& keyword) const
in file db/dictionary/dictionary.C at line 456.
FOAM exiting
I can see that i have some problems in the "0" directory, pressure file, from line 24 to 30. My initial presseure file looks like this:
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0 0 0;
boundaryField
inlet
type fixedValue;
value uniform 10 0 0
empty
type empty;
I do not understand why my "sides" are "undefined".
Could someone please help me ?
Alex
foamer is offline   Reply With Quote
Old   October 23, 2011, 16:20
Alexander
Hi
I know now what is my problem. And as simply as it sounds: I did not execute the setFields file.
Now i am running my case as the original shocktube tutorial without any changes.
However, when i am executing setFields, i am only geeting the error message:
wrong number of arguments, expect 0 found 2.
Can someone please tell me what is wrong and how i can get this tutorial to run properly ? I really want to know how i can make this work.
Alex
Old   October 24, 2011, 09:23
Bernhard Linseisen
Linse is on a distinguished road
Hi Alexander,
maybe I can shed some light onto the problem.
- The first problem simply comes from the "sides" not being defined within the initial pressure file while they are defined within your basic blockMeshDict (or another geometry dictionary). I guess some changeDict or something with a similar name does add these definitions/initial values.
At least I would get this error-message everytime I forget to specify a boundary within my initial setup-files. ;-)
- Concerning the setFields-problem: Could you please specify what options you use for that (just copy-paste the command you use to this thread)? I do not remember the correct use of it by heart, but usually that happens if you try to tell setFields too much, like having non-usable parameters while executing it...
Linse is offline   Reply With Quote
Old   October 24, 2011, 11:53
Alexander
Hi Bernhard, thanks for your reply.
this is how my setFieldsDict file looks like:
| \\ / O peration | Version: 1.7.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object setFieldsDict;
defaultFieldValues ( volVectorFieldValue U ( 0 0 0 ) volScalarFieldValue T 348.432 volScalarFieldValue p 100000 );
regions ( boxToCell { box ( 0 -1 -1 ) ( 5 1 1 ) ; fieldValues ( volScalarFieldValue T 278.746 volScalarFieldValue p 10000 ) ; } );
This is by the way the original setFieldsDict file, without any changes.
Alex
Old   January 2, 2013, 09:47
Exclamation Regarding Setfieldfile
Himanshu Sharma
himanshu28 is on a distinguished road
hi Alex,
i Just want to Know how do u excuted set field for to debug the error i am also trying to run the tutorial but is giving me the error as shown below I am new to open Foam if you can put some views on it...
vaio@ubuntu:~/OpenFOAM/vaio-2.1.1/run/shockTube$ rhoCentralFoam
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
Build : 2.1.1-221db2718bbb
Exec : rhoCentralFoam
Date : Jan 02 2013
Time : 20:14:57
Host : "ubuntu"
PID : 28170
Case : /home/vaio/OpenFOAM/vaio-2.1.1/run/shockTube
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting turbulence model type laminar
Reading thermophysicalProperties
fluxScheme: Kurganov
Starting time loop
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 void Foam::divide<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<Foam::Vect or<double>, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/rhoCentralFoam"
#4 Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvsPatchField, Foam::surfaceMesh> > Foam:perator/<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<Foam::Vect or<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/rhoCentralFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
Thanks
himanshu28 is offline   Reply With Quote
Old   January 5, 2013, 09:03
Alexander
Hi, could you please post your setfield file for me so i can have a look at it?
Alex
Old   January 5, 2013, 10:02
A.R.Sangtabi
noshirvan is on a distinguished road
Alex
hello alex
please run this tutorial with ./Allrun
if you dont have any error,look at in tutorial's file to found your problem
shockTube.zip
noshirvan is offline   Reply With Quote
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
