MRFSimpleFoam implementation questions
Like Tree2Likes
  • 2 Post By chegdan
Old   February 15, 2013, 05:51
Question MRFSimpleFoam implementation questions
Florian
Horus is on a distinguished road
I''m digging into the MRF implementation of MRFSimpleFoam.
For understanding the mathematics I've found [1] and [2].
The MRFSimpleFoam source code [3]. The rhs of the momentum equation is added a sources term for coriolis forces.
pEqn.H calls mrfZones.relativeFlux(phi); which "makes the given absolute mass/vol flux relative within the MRF region". So we are working with relative velocity, correct?
In MRFZone.C [4] Foam::MRFZone::addCoriolis(fvVectorMatrix& UEqn) is called. It adds the source term Usource[celli] -= V[celli]*(Omega ^ U[celli]); to every cell within the MRF zone.
U is relative velocity, V is the cell volume, Omega the rotating axis/frequency, ^ the cross product.
- If we're using relative velocity, doesn't the coriolis term needs to be 2 * omega ^ Urel ?
- Where is the centripetal force term omega ^ omega ^ r? Is is contained in fvm::laplacian(rAU, p) in pEqn?
- Why the cell volume? The compressible addCoriolis function uses -V * rho which is mass...
Thanks for any clarifications!
Florian
[1] http://openfoamwiki.net/index.php/Se...RF_development
[2] http://openfoamwiki.net/index.php/Si...ry_MRF_Library
[3] http://foam.sourceforge.net/docs/cpp...e79dad982.html
[4] http://foam.sourceforge.net/docs/cpp/a03948_source.html
Horus is offline   Reply With Quote
Old   February 22, 2013, 03:42
Florian
Dare to bump that...
Old   February 22, 2013, 16:25
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Florian,
Glad you asked this question, it made me look at it MRF solvers a little more closely.
The velocity in MRFSimpleFOAM is in absolute velocity, therefore the Coriolis acceleration is correctly formulated and rolled into a single term with centripetal force.
For absolute velocity, the centripetal force and coriolis force collapse into the single form
V_{cell}(\vec{\omega}\times\vec{U})
The incompressible formulation of the momentum transport equation has already been divided by rho. Hence why we use nu ( mu divide by rho) and density normalized pressure (in terms of pressure divided by rho...check the units of pressure in simpleFoam cases). Therefore the multiplication of the source term by cell volume is necessary to get the units of force.
Horus and kiddmax like this.
Last edited by chegdan; February 22, 2013 at 16:44. Reason: added more information
chegdan is offline   Reply With Quote
Old   February 25, 2013, 08:09
Florian
Originally Posted by chegdan View Post
Florian,
Thanks for your reply!
The equation used is Eqn. 6 at http://openfoamwiki.net/index.php/Se...RF_development . Correct?
There is the expression
\nabla \cdot (\vec u_R \otimes \vec u_I)
The dyadic product of relative and absolute velocity. I still don't really understand where this expression has gone in the source code?
Thanks!
Florian
Old   February 25, 2013, 10:37
Daniel P. Combest
Florian,
Glancing at other CFD packages documentation and the formulation for MRF solvers, I do see this term as well and seems that it would make sense that the advection term
\nabla\cdot(\vec{U_R}\vec{U}),
should in fact be in there somewhere. If the absolute velocity is the variable of interest, then U_R is related to phi and coupled explicitly through some phi adjustment.
If you look further in the MRFSimpleFoam, you will see the pEqn.H. In that file there is a method that is called that adjusts the flux for this:
If you look into the files located in
$FOAM_SRC/finiteVolume/cfdTools/general/MRF
You will see the
relativeFlux()
method definition. Good luck and i hope this helps!
Old   December 19, 2013, 09:07
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
I have one question regarding the unsteady term of Eq. 6 in [1]. There, the relative velocity appears in the time derivative.
Am I correct, that OpenFOAM computes the absolute velocity in all zones?
If that is the case: why is the relative velocity in the unsteady term?
Maybe one of you can elaborate.
Cheers,
GerhardHolzinger is offline   Reply With Quote
Old   March 14, 2014, 04:58
antoniofct is on a distinguished road
Hi guys.
I have a question regarding MRF.
I have printed the output of UEqn.source() (meaning Usource[celli] -= V[celli]*(Omega ^ U[celli]) ) before and after adding coriolis term ( mrfzones.addCoriolis(rho, UEqn) ), and it prints the same. Why isnt the UEqn being updated??
Thanks
antoniofct is offline   Reply With Quote
Old   March 15, 2014, 09:59
Julian Langowski
Ruli is on a distinguished road
Yep, that`s true
Looking at http://openfoamwiki.net/index.php/Se...RF_development the temporal term of the 'original' NS equation is transformed into its relative formulation, which leads to U_rel in unsteady term. This term is not affected by the further simplifications. I guess it is treated explicitely.
Best regards
Julian
πάντα ῥεῖ - Heraclitus
Ruli is offline   Reply With Quote
Wall functions - questions about implementation AlmostSurelyRob OpenFOAM Programming & Development 44 May 6, 2020 10:11
MRFSimpleFoam Tutorial bastil OpenFOAM Running, Solving & CFD 48 August 1, 2012 10:00
GGI implementation in MRFSimpleFoam amgode OpenFOAM Running, Solving & CFD 8 August 5, 2011 06:03
about MRFSimpleFoam and ggi wllmk1 OpenFOAM Running, Solving & CFD 0 February 5, 2011 04:52
Implementation issues of fvSchemes / laplacianScheme, in particular gaussLaplacianSch thomek OpenFOAM Programming & Development 0 October 18, 2010 05:10
