Initial residuals do not decrease...
Old   June 28, 2011, 15:51
Default Initial residuals do not decrease...
Igor_2011 is on a distinguished road
Hi everyone!
I'm rookie on the forum and I'd like to start by greeting all the members for the very interesting topics that are being discussed here.
I recently tried to simulate the unsteady around a basic 2-D cylinder using the solvers available in OpenFoam, in particular pimpleDyMFoam. Basically the code I use is the looks like:
        // Do any mesh changes
        mesh.update();
        // Make the fluxes relative to the mesh motion
        fvc::makeRelative(phi, U);
        if (mesh.changing() )
            #include "meshCourantNo.H"
       for (int ocorr=0; ocorr<nOuterCorr; ocorr++)
        // Pressure-velocity SIMPLE corrector
            #include "UEqn.H"
            #include "pEqn.H"
        turbulence->correct();
where the velocity and pressure are solved in the following parts:
    // Solve the Momentum equation
    fvVectorMatrix UEqn
    fvm::ddt(U)
       +fvm::div(phi, U)
      + turbulence->divDevReff(U)
    UEqn.relax();
    eqnResidual = solve
        UEqn == -fvc::grad(p)
    ).initialResidual();
    maxResidual = max(eqnResidual, maxResidual);
    p.boundaryField().updateCoeffs();
    volScalarField AU = UEqn.A();
    U = UEqn.H()/AU;
    //UEqn.clear();
    phi = fvc::interpolate(U) & mesh.Sf();
    adjustPhi(phi, U, p);
    // Non-orthogonal pressure corrector loop
    for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
        fvScalarMatrix pEqn
            fvm::laplacian(1.0/AU, p) == fvc::div(phi)
        pEqn.setReference(pRefCell, pRefValue);
        if (nonOrth == 0)
            eqnResidual = pEqn.solve().initialResidual();
        else if( ocorr == nOuterCorr-1 && nonOrth == nNonOrthCorr)
                        pEqn.solve(mesh.solver(p.name() + "Final"));
        else
            pEqn.solve();
        if (nonOrth == nNonOrthCorr)
            phi -= pEqn.flux();
#   include "continuityErrs.H"
    // Explicitly relax pressure for momentum corrector
    p.relax();
    // Momentum corrector
    U -= fvc::grad(p)/AU;
    U.correctBoundaryConditions();
As you can see, two inner loops are performed during each iterations. From top to bottom:
  1. loop for non-orthogonality correction on the pressure equation (nCorr
  2. velocity- pressure correcion
My question here concerns the initial residual at the beginning of each inner iterations. Typically for nNonOrthCorr=3 and nOuterCorr=2 the following residual history is obtained:
Mesh Courant Number mean: 1.03403 max: 1645.15
smoothSolver:  Solving for Ux, Initial residual = 0.000663609, Final residual = 2.88668e-06, No Iterations 8
smoothSolver:  Solving for Uz, Initial residual = 0.00548648, Final residual = 2.28391e-05, No Iterations 8
DICPCG:  Solving for p, Initial residual = 0.828448, Final residual = 9.83331e-07, No Iterations 506
DICPCG:  Solving for p, Initial residual = 0.211827, Final residual = 9.78121e-07, No Iterations 478
DICPCG:  Solving for p, Initial residual = 0.0673258, Final residual = 9.56774e-07, No Iterations 468
time step continuity errors : sum local = 5.6259e-12, global = 4.41739e-20, cumulative = 1.4129e-19
smoothSolver:  Solving for omega, Initial residual = 7.3622e-06, Final residual = 7.40485e-09, No Iterations 4
smoothSolver:  Solving for k, Initial residual = 0.0114753, Final residual = 3.82431e-06, No Iterations 3
smoothSolver:  Solving for Ux, Initial residual = 0.000132713, Final residual = 1.01532e-06, No Iterations 8
smoothSolver:  Solving for Uz, Initial residual = 0.000974607, Final residual = 6.52005e-06, No Iterations 8
DICPCG:  Solving for p, Initial residual = 0.804658, Final residual = 9.75985e-07, No Iterations 513
DICPCG:  Solving for p, Initial residual = 0.241636, Final residual = 9.50152e-07, No Iterations 481
DICPCG:  Solving for p, Initial residual = 0.0714927, Final residual = 9.76869e-07, No Iterations 458
time step continuity errors : sum local = 5.33943e-12, global = 1.72288e-20, cumulative = 1.58519e-19
smoothSolver:  Solving for omega, Initial residual = 1.39838e-06, Final residual = 8.80479e-09, No Iterations 3
smoothSolver:  Solving for k, Initial residual = 0.00313893, Final residual = 1.69267e-06, No Iterations 3
and I don't understand why my initial residual for the pressure is not equal to the final residual at the previous sub-iteration. In particular, should I consider the case to be converged when the first initial residual is below a pre-defined threshold?
I'm a beginner in CFD so do not hesitate to correct or highlight any misinterpretations or vocabulary misuses.
Great thanks!
Igor
Igor_2011 is offline   Reply With Quote
Old   July 11, 2011, 14:05
L1011 is on a distinguished road
I'm also interested by this post, nobody has a clue?
L1011 is offline   Reply With Quote
Old   March 6, 2013, 13:07
Yahoo is on a distinguished road
I am trying to solve equation
fvScalarMatrix CEqn
fvm::ddt(C)
+ fvm::div(phi, C)
CeqnResidual = CEqn.solve().initialResidual();
In case where phi is zero (i.e. no flow), my initial residuals are always high (~ 0.3). When I am forcing the solver to exit without satisfying the convergence criterion (by setting a maximum for the iterations), I see that phi is zero everywhere and C is constant, as I expect. But, I don't know why CeqnResidual is high!
Yahoo is offline   Reply With Quote
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
