Momentum predictor
Like Tree10Likes
  • 2 Post By santiagomarquezd
  • 7 Post By santiagomarquezd
  • 1 Post By Andrea_85
Old   July 12, 2011, 10:25
Default Momentum predictor
Andrea Ferrari
Andrea_85 is on a distinguished road
Hi all,
i have 2 questions about the solution procedure in interFoam.
The predicted fluxes are bulid in pEqn.H, if i'm not wrong:
volScalarField rAU(1.0/UEqn.A());
00003     surfaceScalarField rAUf(fvc::interpolate(rAU));
00004
00005     U = rAU*UEqn.H();
00006     surfaceScalarField phiU
00007     (
00008         "phiU",
00009         (fvc::interpolate(U) & mesh.Sf())
00010       + fvc::ddtPhiCorr(rAU, rho, U, phi)
00011     );
00012
00013     adjustPhi(phiU, U, p_rgh);
00014
00015     phi = phiU +
00016     (
00017         fvc::interpolate(interface.sigmaK())*fvc::snGrad(alpha1)
00018       - ghf*fvc::snGrad(rho)
00019     )*rAUf*mesh.magSf();
what is the difference between switch on or switch off the momentum predictor in uEqn.H and how it affects the predicted velocities?. What does OF calculate in:
00019     if (pimple.momentumPredictor())
00020     {
00021         solve
00022         (
00023             UEqn
00024          ==
00025             fvc::reconstruct
00026             (
00027                 (
00028                     fvc::interpolate(interface.sigmaK())*fvc::snGrad(alpha1)
00029                   - ghf*fvc::snGrad(rho)
00030                   - fvc::snGrad(p_rgh)
00031                 ) * mesh.magSf()
00032             )
00033         );
00034     }
the second quesiton is: What does it mean
fvc::ddtPhiCorr(rAU, rho, U, phi) in the phiU calculation?
thanks a lot in advance
andrea
Andrea_85 is offline   Reply With Quote
Old   July 19, 2011, 18:52
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Andrea, predicted velocity is taken into account in H method (check Hrv Thesis). ddtPhiCorr is intended to apply a correction to Rhie-Chow interpolation due temporal scheme.
Regards.
Tushar@cfd and amolrajan like this.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   July 20, 2011, 03:49
Andrea Ferrari
Hi Santiago and thanks to your reply.
If i'm not wrong, H is a function of U (it takes into into account the velocities of the neighboring cells). So, if the momentum predictor is turned off, which is the velocity used to bulid up H?
Or in another way, are these lines (below) used to calculate a velocity or are used only to do an update of the coefficients of the matrices A and H?
00020 {
00021 solve
00022 (
00023 UEqn
00024 ==
00026 (
00027 (
00032 )
00033 );
00034 }
Old   July 20, 2011, 09:29
Andrea, if momentum predictor is turned off, U from previous time-step is used, if it is on once the solve method is executed U is refreshed and then used in H method.
Regards.
lth, kaifu, minh khang and 4 others like this.
Research Scientist
Old   July 20, 2011, 09:35
Andrea Ferrari
Ok, now it's totally clear!!
many thanks
andrea
Old   July 22, 2011, 07:04
Andrea Ferrari
Hi Santiago,
i'm still a little bit confused about the velocity reconstruction after the pressure solution.
U += rAU*fvc::reconstruct((phi - phiU)/rAUf);
Why phiU is substracted from the fluxes?
phiU is defined as the sum of the predicted velocity interpolated to the faces and the temporal correction. The contribution of H/A is included in the new velocity because of "+=", so which contribution is substructed? Is the temporal correction?
thanks again
andrea
giack likes this.
Old   March 11, 2013, 04:09
giack is on a distinguished road
Originally Posted by Andrea_85 View Post
Hi Santiago,
thanks again
andrea
do you find a solution to this question? I'am the same question..i tried to compare it with the PISO algorithm but in the PISO algorithm the this U reconstruction is as follow:
U -= rUA*fvc::grad(p);
thanks for help
giack is offline   Reply With Quote
Momentum source coefficient and convergence meh CFX 9 October 12, 2020 08:37
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
Why sometimes momentum predictor step is not performed liu OpenFOAM Running, Solving & CFD 10 July 3, 2005 06:56
Nonstaggered Grids and Momentum Interpolations S. Wang Main CFD Forum 3 March 2, 2001 13:44
