Tank emptying
Like Tree1Likes
  • 1 Post By Andrea1984
Old   September 28, 2012, 07:52
Default Tank emptying
Andrea
Andrea1984 is on a distinguished road
I'm trying to simulate the emptying of a tank with OF.
As I'm a newbie in OF, i have some doubt about the BCs.
The tank is 25x25 cm and has an height of 7 cm; the water height is equal to 5 cm and is drained through an hole at its bottom (d=1.3 cm).
The top of the tank is opened to atmosphere.
My doubt are about the boundary conditions for pressure and alpha1.
For the pressure I'm thinking to use a TotalPressure bc at the top (the same used in the DamBreak tutorial), zeroGradient at the outlet and zeroGradient at the wall (or should I use buoyantPressure for the walls?)
For alpha1 I want to use 0 for the top (only air), 1 for the outlet (only water) and zeroGradient at the walls.
Are this settings right?
Any tips about this particular case are welcome!
Thank you in advance.
Andrea
Mahmoud Abbaszadeh likes this.
Andrea1984 is offline   Reply With Quote
Old   September 29, 2012, 04:35
Jan
SirWombat is on a distinguished road
Send a message via Skype™ to SirWombat
i suggest totalPressure for pressure at the outlet. make the water flow out to the atmospheric pressure (probably 0 if you haven't defined it) or use fixedValue = 0. you can use pressureInletOutletVelocity for the velocity at the outlet
SirWombat is offline   Reply With Quote
Old   September 30, 2012, 04:38
nsf
Nicolas Edh
nsf is on a distinguished road
I would set inletOutlet on alpha1 on the outlet. If you on some point get a vortex which transports air out through the outlet you'll get into trouble if you prescribe a fixedValue.
Good luck!
nsf is offline   Reply With Quote
Old   October 1, 2012, 07:16
Default problem with total pressure = 0
Sam-CFD's Avatar
Sam Mathew
Sam-CFD is on a distinguished road
On a sample problem, I've tried the same boundary condition on the bottom outlet as top atmosphere; which effectively means,
p_rgh (p - rho*g*h) being totalPressure
U being pressureInletOutletVelocity
alpha1 being inletOutlet
When I compare it to the analytical expression for the outlet flow rate and velocity {i.e., sqrt(2*g*h)}, the OpenFOAM results are around 1/3rd this value.
I performed the simulation in ANSYS FLUENT with Pressure Inlet (total gauge pressure = 0) and Pressure Outlet (static pressure outlet = 0) and the results seem to be acceptable to the analytical expression with some slight reduction due to viscous and other losses.
So, I am not quite sure if the boundary conditions suggested above are really correct?!
Any comments from others who have experience?
Thanks and regards,
Sam
Sam-CFD is offline   Reply With Quote
Old   October 1, 2012, 13:15
nsf
Nicolas Edh
Have a look in
 ...tutorials/multiphase/interFoam/ras/waterChannel
In the tutorial, they set buoyantPressure for p_rgh on all patches except the atmospheric patch. Where the set totalPressure.
For U on the outlet it's inletOutlet.
They do set zeroGradient on alpha at the outlet. Which I think is fine unless there is any risk of reversed flow. In that case I would use inletOutlet.
Let us know how it goes!
/Nicolas
Old   October 2, 2012, 04:18
Jan
Sam
When, how and where did you measure the velocity of the outflow? If no water is flowing into the tank then the velocity is a function of the height of the remaining waterlevel ... did you take this into account?
~~~_/)~~~
Old   October 2, 2012, 08:09
Andrea
I have a fixed value for the flow rate at the outlet so I'm using a fixedValue for the velocity and zeroGradient for the pressure.
I think my problem is with the BCs at the wall, as I obtain a strange velocity field at the wall proximity using buoyantPressure (see attached picture, U contour at free surface).
Old   October 3, 2012, 02:11
Sam-CFD's Avatar
Sam Mathew
Thanks for your responses.
I want to obtain the velocity at the outlet from the simulation and compare it with the analytical solution.
v = sqrt(2*g*h)
where, h = height of the liquid presently in the column.
Unlike Andrea's case, my problem involves a tank draining under gravity; therefore, I have to have a boundary condition on the outlet similar to static pressure = 0 (in ANSYS FLUENT).
I am expecting backflow at the outlet and gas to ingest into the domain. Primarily the aim is to verify whether, vortex from the top free-surface enters into the outlet.
Regards,
Sam
Old   April 5, 2013, 09:29
giack is on a distinguished road
Hi to all,
I have a problem with the setting of the boundary condition in a similar problem.
My case is summarized as follow:
at the initial time t=0 the right wall of a closed tube completely filled with liquid is removed, allowing the liquid to exit the domain and, at the same time, allowing the gas to enter.
I set the BC in this way:
left wall: "p" zero gradient "U" fixed value (0,0,0) "alpha1" fixed value 1
pipe wall: "p" zero gradient "U" fixed value (0,0,0) "alpha1" zero gradient
right wall (outlet): "p" total pressure "U" pressureInletOutletVelocity "alpha1" inletOutlet
but I obtain unphysical result
Where is the error?Someone have an idea to set BC for this case?
thank to all
giack is offline   Reply With Quote
Old   April 5, 2013, 12:43
nsf
Nicolas Edh
Hi giack,
I once hade a problem with interFoam where alpha was unphysically diffused through the walls. This was resolved (for Of 2.1) by setting
    walls
        type            buoyantPressure;
        gradient        uniform 0;
        value           uniform 0;
on the wall patches. I think you should have zeroGradient on alpha on the left wall as well.
So for the patches that are walls (left and pipe) you should have the same bc's and they should be
velocity: fixedValue (0 0 0)
p_rgh: buoyantPressure (as above)
alpha: zeroGradient
I think the right wall is correct.
Good luck
Nicolas
Old   April 7, 2013, 05:56
thank you for your reply. I apply the suggestion that you give me but the problem remain the same...I think that there is something wrong in the set of pressure at the outlet but I don't understand what it is... Any ideas?
Surge tank emptying using interFoam- Stops when surface reaches outlet Ramnik OpenFOAM Running, Solving & CFD 1 March 14, 2012 07:26
Surge tank emptying using InterFAOM- Stops when surface reaches outlet Ramnik OpenFOAM Running, Solving & CFD 0 May 26, 2010 10:42
Emptying tank & Multiphase Ruggero Siemens 18 October 24, 2007 12:23
How can i simulate a emptying bi-phasic tank? Ruggero FLUENT 1 July 9, 2007 02:17
Emptying of a tank Mario CFX 2 September 29, 2006 10:51
