Need a solver for a trans-sonic simulation
Old   May 15, 2013, 03:52
Default Need a solver for a trans-sonic simulation
Spaceprofessor is on a distinguished road
Hi All,
I have been running a simulation of a land speed vehicle at several differents speeds using sonicFoam. This works very well, until the Mach number is less than 1 (ie: subsonic). I have tried rhoSimpleFoam and rhoCentralFoam and they do not give me results either.
Can anyone suggest a solver that I can use for mach numbers between 0.8 and 1?
I have no mesh motion if this helps.
Thanks in advance!!
Spaceprofessor is offline   Reply With Quote
Old   May 15, 2013, 04:45
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Originally Posted by Spaceprofessor View Post
Hi All,
regardless of the transonic switch?
niklas is offline   Reply With Quote
Old   May 15, 2013, 05:16
Sorry, I do not understand what you mean?
I won't be using this solver above Mach 1.
Old   May 15, 2013, 06:22
niklas's Avatar
Niklas Nordin
In the SIMPLE dictionary in fvSolution
you can set
transonic on;
or
transonic off;
If you dont specify it, it is set to off by default and that is what you have been using, but Im just wondering
if it will work better if you set it to on...even if you run subsonic, you might not be subsonic
in the iterations leading up there.
Old   May 15, 2013, 06:24
niklas's Avatar
Niklas Nordin
btw, this is just for the rhoSimpleFoam solver
rhocentralfoam, rhosimplefoam, sonicfoam, trans-sonic
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
smoothSolver diverges - solution in using PBiCG solver? makaveli_lcf OpenFOAM Running, Solving & CFD 3 September 11, 2013 12:44
Diverging Simulation using rhoSimplecFoam, kOmegaSST AndreasP. OpenFOAM Running, Solving & CFD 4 March 30, 2013 10:12
How calculate simulation duration - CFX Solver eRzBeNgEl CFX 3 January 24, 2011 16:35
Getting too many iterations by velocity solving (aborting). Changing U - Solver? suitup OpenFOAM Running, Solving & CFD 0 January 20, 2010 07:45
