Error when I try a case with pimple instead of simple solver
Like Tree4Likes
  • 4 Post By jherb
Old   June 4, 2013, 10:55
Default Error when I try a case with pimple instead of simple solver
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I have a problem with a transient simulation. Actually, I do have a case with a steady solution and I have calculated it.
I am now trying to calculate the same solution as the limit of the unsteady counterpart.
But as soos as I run
buoyanPimpleFoam
instead of
buoyanSimpleFoam
I get this error message:
lab@lab-laptop:~/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/NOPCM/pseudoTransient$ buoyantPimpleFoam
|  \\    /   O peration     | Version:  2.1.0                                 |
Build  : 2.1.0-0bc225064152
Exec   : buoyantPimpleFoam
Date   : Jun 04 2013
Time   : 16:30:09
Host   : "lab-laptop"
PID    : 4178
Case   : /home/lab/Documenti/Ethics/FRISBEE/CFD/testVerticalTN_PCM/NOPCM/pseudoTransient
nProcs : 1
Create time
Create mesh for time = 0
Reading g
Reading thermophysical properties
Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
--> Upgrading k to employ run-time selectable wall functions
    Backup original k to k.old
    Writing updated k
--> Upgrading epsilon to employ run-time selectable wall functions
    Backup original epsilon to epsilon.old
    Writing updated epsilon
--> Creating mut to employ run-time selectable wall functions
    Writing new mut
--> Creating alphat to employ run-time selectable wall functions
    Writing new alphat
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
    Prt             1;
Calculating field g.h
Reading field p_rgh
Creating field dpdt
Creating field kinetic energy K
Courant Number mean: 0 max: 0
--> FOAM FATAL ERROR:
Residual data for p_rgh must be specified as a dictionary
    From function bool Foam::solutionControl::read()
    in file cfdTools/general/solutionControl/solutionControl/solutionControl.C at line 79.
FOAM exiting
Could you please help?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   June 4, 2013, 11:11
Samuele Z
I forgot my fvSolution file. Here it is:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0.01;
    "(U|h|k|epsilon)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-05;
        relTol          0.1;
    G
        $p_rgh;
        tolerance       1e-05;
        relTol          0.1;
PIMPLE
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
    residualControl
        p_rgh           1e-2;
        U               1e-3;
        h               1e-3;
        G               1e-3;
relaxationFactors
    fields
        rho             1.0;
        p_rgh           0.7;
    equations
        U               0.2;
        h               0.2;
        "(k|epsilon|R)" 0.5;
        G               0.7;
Old   June 5, 2013, 02:36
Ank
ankur
Ank is on a distinguished road
Hey
I did not understand the problem completely but you can make a small change in your fvSolution by this
PIMPLE
pRefCell 0;
pRefValue 0;
residualControl
p_rgh 1e-2;
U 1e-3;
h 1e-3;
G 1e-3;
replace it by this
PIMPLE
momentumPredictor no;
nOuterCorrectors 1;
nCorrectors 2;
pRefCell 0;
pRefValue 0;
relaxationFactors
p 0.7;
U 0.3;
T 0.5;
k 0.5;
omega 0.5;
nut 0.5;
R 0.5;
nuTilda 0.5;
see if it works.
Ank is offline   Reply With Quote
Old   June 5, 2013, 02:47
Samuele Z
I get this error
Date   : Jun 05 2013
Time   : 08:44:24
Host   : "lab-laptop"
PID    : 2367
nProcs : 1
Create time
Reading g
Reading field U
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
    Prt             1;
Reading field p_rgh
Creating field dpdt
PIMPLE: Operating solver in PISO mode
Starting time loop
Time = 0.1
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5  Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#7  Foam::fvMatrix<double>::solve() in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/buoyantPimpleFoam"
#9  __libc_start_main in "/lib/libc.so.6"
Floating point exception
It is probably due to the BC. But using the steady solver it works fine and I can not und why.
Old   June 5, 2013, 02:52
Ank
ankur
Can you describe your case a little bit? and the boundary conditions as welll
Old   June 5, 2013, 04:16
Samuele Z
Sure. I can share it, if you agree. Please, send an email to samuele.zampini@gmail.com and I'll send the case back to you.
Old   July 29, 2013, 12:56
Default residualControl
Joachim Herb
jherb is on a distinguished road
I got the same error message as you and was able to fix it by adding this to my fvSolution file:
    residualControl
        p_rgh
            relTol          0;
            tolerance       0.0001;
        U
            relTol          0;
            tolerance       0.0001;
        h
            relTol          0;
            tolerance       0.0001;
        // possibly check turbulence fields
        "(k|epsilon|omega)"        {
            relTol          0;
            tolerance       0.0001;
I guess that buoyantPimpleFoam expects the residual control information in this way "as a dictionary", i.e. inside braces with the two entries relTol and tolerance (the latter is probably the absolute value of the residual whereas the first one is the change between two time steps). buoyantSimpleFoam does not need the relTol as there are no time steps.
Joachim
Originally Posted by samiam1000 View Post
buoyantSimpleFoam
FOAM exiting
nimasam, gaza, amgh and 1 others like this.
jherb is offline   Reply With Quote
snappyMesh Motor Bike case for simpleFoam solver s.sivakumar OpenFOAM Pre-Processing 0 July 23, 2009 00:51
snappyMesh Motor Bike case for simpleFoam solver s.sivakumar OpenFOAM Running, Solving & CFD 0 July 22, 2009 08:00
Simple 2d Matlab Solver Gabriel Usera Main CFD Forum 7 May 14, 2007 00:11
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Swirl momentum in SIMPLE based FV solver oz Main CFD Forum 0 February 10, 2006 16:25
